Hey guys, had to remove some intercooler piping on my car the other day and I took it for a drive after and I noticed my water temp gauge was about 20degrees hotter than what it usually gets to (was going through drive-through). Had a look under the engine bay and sure enough the piping had moved forward and was stopping the radiator fan from spinning.
Loosened a hose clamp and pushed the piping back towards the firewall and retightened but last night it must've come loose somehow (could be the slippery paint finish on piping) and had stopped the fan again (thank god for the water temp gauge).
I've seen some set-ups that have a bracket welded onto the intercooler piping and it secures to the cam cover. Are there any other options? Who makes front facing plenums for Rb20dets and how much are they?
ALso my thermo fan doesnt work (looks like the wiring has been cut). Is this easy to hook back up or should I take it to an auto elec?
It never over heats but I figure having the thermo working would be even better?
Thanks.
https://www.sau.com.au/forums/topic/145111-fmic-piping-hitting-radiator-fan/
is it a just jap cooler kit?i just installed one, i thought that would be a problem but after a good thrash the piping hasnt moved. best thing to do would be to make a bracket
as far as plenums plazmamann make a plenum kit that relocates the throttle bodyso it is facing the front of the car. its about 800 or something. imo if you are not chasing huge power it is a waste of money. just make a bracket
if you dont know what wires to connect to where go to a auto electrician and they will sort it out quickly
just a side question. afte installing your cooler are the cooler pipes in the engine hot?
Hey Oliver, thanks for your reply.
It's just custom piping (the FMIC was already on there when i bought the car). It never came loose before but I had to take off some piping to get to something on my engine and now the piping is moving and hitting the fan.
"just a side question. afte installing your cooler are the cooler pipes in the engine hot?" If you mean the intercooler piping that is under the engine bay, close to the engine, then yes mine gets a bit hot too.
soemone told me to do the same thing, but to me that looks dodgy as hell! make a bracket and push the cooler piping away from the fans as much as possible
We cut the fan blades back on my r33 using a little alloy template we made. Not dodgy if you do it right. What is dodgy is when the fan continues to hit the piping regularly and fractures the fan blades! Thats what happened to mine, had to buy a complete fan unit to replace it, not cheap!
Does the thermo have anything to do with the air con? Normally on cars thay have a fan that runs for the a/c as well as an engine cool fan?
Hey,
I dont know if it has been mentioned but when i had this problem i used a bit of rough sand paper that i had stuck on the pipe where it was hitting the fan blades. This sanded away the fan blades after a few days.
Also it pays to make sure that all the hoses are tight and that the pipes are deep inside the joiners so there is little to no play in the pipes.
Hey guys im in the same situation. If you cut the blades down on the fan is it still roadworthy? Also if you cut a hole for the cooler piping underneath battery is that roadworthy this is for a 34?
Thanks guys!
    • Absolute Legend 🍻 After fighting with the scanned ones for the last 10 years this is a God send
    • ATTAKD 356mm Brake Kit for R34 GTT or R33 GTST. Same brake kit as per here from JJ: https://justjap.com/products/attkd-brake-kit-nissan-skyline-r34-99-02?currency=AUD Can confirm these will bolt directly to a R33 GTST with 12mm bolts OR to a R34 GTT (which is what I had) with the supplied bolts and the collets for the 14mm bolt holes in the R34, which are included. Also included is a set of rotors and hats, as well as 2x brake pad sets. 1) DBA XP (street, hills) 2) Forza FR6 (track) These are radial mounted and bolt directly to R33/R34. You will need extended brake lines to avoid them being full stretch on lock - this is common for all BBK's with the bolt point being in the center. In my case I welded another stud about 25mm lower than the OEM one and retained stock lines and fittings. You'll want a BM57 BMC to get the most out of these. I speak from experience. $1800 (neg for SAU people), located SE Suburbs Melbourne.
    • Set of R33 GTST Calipers, Rotors and Pads. Calipers just taken off my car, rebuilt about ~30,000km ago. Rotors have done about ~20,000km total since new. Pads have plenty of meat. One set is DBA XP (road, hills) and the other set is Forza FR6 (track) Still working perfectly, not rusted, or seized or whatever the hell that greets used brakes. All clips, bolts, retainers, slide pins etc included. Also have OEM handbrake shoes I can throw in there if you're doing a conversion. $650 for the lot, SE Suburbs Melboune/VIC
    • I feel I have covid right now. I spent the time between Dec 21 and Jan 31 pretty much working 16 hour days on the car after it got back from paint. It turns out you generate a long list of "things to do" while the car is off the road but functional. After going to visit my mate for a "Couple of hour job" doing the brakes, 3 full days later I got home There was more on the list, (it got added to while sleeping on couches) but as everything on the list got enthusiastically crossed out as it happened, I've actually forgotten what they were. From memory there were bushes that had to be pressed in and out, washer jets to fit, etc. Some Gregging highlights: 1) The panel shop covered up my washer jets and painted over it. Good job, I think. We had to drill the new bonnet to fit new ones, which was understandably extremely scary. 2) My handbrake on the RHS is f**ked. After never adjusting it forever and learning on the fly, this one is still on my to-do list. It tightens when you pull the lever, but at about 10% of the tension that the passenger side does. Thoughts on what causes this would be great. 3) Pouring an entire liter of brake fluid over the reservoir because I forgot how to use my pressure bleeder. DON'T PUT FLUID IN THE RESERVOIR. IT WORKS BY USING PRESSURIZED AIR NOT PRESSURIZED FLUID.   471907729_9242915229093447_2708910336906717367_n.mp4  I can confirm the vents work great though. 4) Some of the bodykit fixings were f**king awful. I'm talking screwed in with what was at most a 2mm screw, and could flap the kit around by hand. Too many others to mention. They came in, went out of my brain forced by other stupid tiny things that came up and "While the car is on the damn hoist we can fix them" which was a mission in and of itself, because the car has skirts and is thus a pain to put on hoists. Because we had to buff the windscreen to get rid of the overspray, I also had to very gently wash the car. The "Run 3 wires" task was to re-attempt another gregging thing which was: The LS1 ECU in Australia does not have oil pressure wiring because the Commodores do not have a 'real' oil pressure switch The Corvettes in the USA do have oil pressure wiring because Corvettes have a real oil pressure switch. The ECU is the same physical ECU. So what I could do is pull the ECU apart, run 3 more pins and run it to the OEM oil pressure ECU, and the ECU should do this. What actually happened is that Greg did this with some not-so-proper-wiring/connectors to the ECU pins which 'might?' be okay put the car back together, and then the fuel pump wouldn't prime. So you can imagine I immediately undid all this work, put the ECU back into it's original configuration, thought I'd do some more research about what connectors the LS1 Ecu actually uses... and try again later. Except still no fuel pump prime. After a lot of sadness and checking/double checking it turns out it was the relay in the boot that controls the fuel pump. All I did was switch the trigger wires and it worked fine. I looked at the relay and it was covered in bog dust and was unknown years old. It's since been replaced and working fine. After I got the actual connectors, and the wires were ran I gathered my strength and repinned the ECU and Voila! I apologize for these MMS  472164532_8829400773820369_5410969472548349643_n.mp4  And even via ODB2 on the headunit, woo. Now Torque Pro can raise hell on track if it gets too low. It has a wonderful EMERGENCY_DISTRESS_SINGAL style warning if it goes below a certain threshhold. 472585876_9345134268844369_146554337148747327_n.mp4 TLDR: Car great. HFM kit works. So much cleaning. Buy my old stuff. Thanks.
    • That's a hell of a question right there and so broad that you could get 100 different answers and have them all be correct.  To avoid me typing up a 2000 word thesis that doesn't answer your question, do you have specific things you are unsure of? Does the car currently handle in a way that you don't like? Or is it closer to, you think the car drives fine currently. But you'd like it to be better, but you don't know what that 'better' is or what that 'better' feels like?
