bad bad bad!!
is it from the radiator? or from the block?? If it is from the block it could be a busted head gasket and its going to cost big $$$ If you continue to drive it you will warp or crack the head resulting in even bigger $$$
If you are lucky.. it is just busted radiator, or split radiator hose. Not that you should be driving it in this condition, but pop the bonnet.. you should see steam shooting out from somewhere - which will narrow it down. If you are lucky it will just be a hose.
My recommendation is not to drive the car at all until you can work out the problem. It most likely is quite serious.
Temperature problems can be FATAL to an engine..especially a modern engine.
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-296076
got your PM pred and thankyou for your help... damn, now im shitting my pants, don't know where exactly it is leaking.. i looked under the car and it has the black shield covering under it so i couldn't tell whether it is the hose, or the block but it is defintely 100% coolant(green liquid). Just went down to the local mobil petrol station and brought some radiator stop leak treatment bottle.. going to add it and hope it helps.. :D:(
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-296330
Guest RedLineGTR
Check the hoses, or remove the cover. Just follow the hoses down to where they end like the bottom one see if there is any fluid leaking. Best Bet is jack it up and take the cover off. I could be the water pump (how many k's) some of them go early before 100k. Or could be a cracked radiator as suggested above. (which is alot less common).
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-296580
I'll put money on it being your water pump. Check the water pump, there is an inspection hole that will allow coolant to slowly leak when the pump seals shit themselves (telling you it's time to replace the pump). With the undertray in place you'll never be able to pin-point the source of the leak. The tray comes off easily.
If the pump is the cause you're up for a new one, & you may as well replace the timing belt while you're there. You need to take the same bits off - so why do it twice?
New pump from Nissan (same as RB30 VL pump) - $90-100
Timing belt - $80-90
Labour - ~$150 (dunno' exactly on this one?)
I very much doubt it'll be a major problem, so don't stress too much :)
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-296690
Originally posted by pushead
I topped up the coolant in the white bottle as well as the alternator last night
Alternator - coolant? WTF! Coolant & the alternator don't mix well dude!
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-296695
???? so you put water instead of coolant in the alternator? i followed a black hose which goes to a white bottle(the backup bottle) which labels coolant.
Checkout the attached Picture:
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-296768
you lucky bastard :D with the temp that hot ur lucky nothing blew
mine ran hot once and blew the seals on the plastic radiator end tanks - goodbye radiator
the water pump is a c*** to get off cos of the crank pulley bolt. you will more than likely need a rattle gun to get this off
the water pump may not be dead, it my just be the seal, in which case pull the pump off, put new sealant around it (doesnt use a gasket) and put it back together
you can drive around with a leak BUT make sure u keep the system topped up
if it starts sucking air or depressurises it will overheat again and u may not be so lucky
take it to a mechanic and there are pressure tests you can do on the radiator so check for a leak/crack. you can also run a test to see if there are exh gases in the system (leaking head gasket) so you will be able to pin-point the problem
just finally, cooling systems are ****s to work on and fix, if youre going to repair it make sure u do it right cos its the kind of thing which if not done properly will cause alot of headaches
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-303732
I would say this is invaluable advice.
Our pumps are cheap which is good.
You want to do pump, timing and accessories belts at once to save labour.
$150 for labour is damn cheap though.
T.
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-304054
I paid $350ish (think it was 350? Certainly under 400) for a new genuine Nissan w/pump & timing belt. Both installed. Thanks Vince (Rigoli).
I didn't want to take any chances so I got them both done. That way I knew they were new :)
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-306926
I very much doubt it'll be a major problem, so don't stress too much :P
Thanks for your detailed info dude.. really needed it...yep. same as the RB30 VL pump.. what hole are you refering to which you can tell the water pump shit itself?.. i couldn't seem to find it.. is it near the fan belt?
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-310998
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
