  • Replies 128
Posted Images
No, the late 90s rodeos came with quadcam 3.2 or 3.5l Isuzu engines. Engine went in this evening. They still have to hook everything up, finish wiring the ecu and tune.......and kill any gremlins. All by at the latest midnight tomorrow so he can drive up to NSW.
Really hope it gets ready in time as this machine is fantastic. No credit card and Nengun catalogue for this thing, everything has been obviously custom as nobody else has played with this engine to that magnitude.
Cool thanks for that :laugh:
To all those out there that have or have not been it was good i enjoyed it
$23 to get in or if you have the $5 off ticket . I would recommend go there are some cars for all
High Power cars and bling and well not so anything type of cars too.
And if you want to have pleanty of eye candy i would also recommend in going too .
anyway all the cars looked good top stuff to the SAU guys for giving it ago :D
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
