  • Replies 40
Look, I successfully use an Apexi SAFCII and an Apexi SITC, running as piggybacks to the ECU, in my automatic 4wd RB25det.
Standard turbo at 12psi pushed 160awkw. I now have a highflow turbo that was just installed last week, and I expect (once tuned) a lazy 200awkw at 1bar without too much of a problem. Off boost economy is fine, on boost it sucks the fuel, obviously.
Has ANYONE run a PowerFc as a Piggyback unit in an auto Skyline? That'd be the way to go, IMO.
If all you disbeleivers care to come check out my car, ill take you for a drive with the stock ECU, then change to the motec (takes about 5 minutes because of the interface i made up to keep the standard harness). I'll defy you to pick ANY difference in gear change. Under full boost ignition is retarded anyway, under cruise there isnt enough torque to damage the box, and line pressure in the box (which is controlled by the AUTO ECU) is alot lower, so the changes arent as harsh anyway.
I second that.
So Paul which is it?
are you coming to sa or going to NSW any time soon?
proof is in the driving, not hear say, or what you have read in some book.
Tell everyone how many auto skylines you have been in in your life!
please dont coment on something that you havent experienced first hand.
as a moderator you shouldnt be influencing people with your wisdom if you know nothing, apart from what you have read.
Im not being harsh im just sick of people arguing with you that its fine and you keep disputing this even tho you have no proof that it doesnt work with a shift kitted auto.
I truly believe the ignition retard is a luxury thing to make the car smoother.
by increasing the shift speed with a shift kit we are by passing this standard design and therfore
bypassing the need for the standard computer.
As far as Mike from MV automatics is concerned the R33 jatco auto is far superior in strength to the vl box, so you tell me the difference!
He has driven my car at near 300 kws and couldnt fault the auto.
but what would he know?
obviously not as much as your pfc book!
Sorry but its the truth.
oh fiddlesticks, i was in nsw about 3 weeks ago sorry.
so because i am a moderator i am not allowed to discuss things and disagree with what someone says? what a load of rubbish. and even if it does drive fine, which it says in my so called book i still dont see how its not making it harsh for the box. but what do i know, like youve said
and its hardly a book, its a self help guide for people asking the same questions over and over. i mean i can delete it if you want and poeple can keep posting the same questions each time, would that be better?
anyhoo we are both set in our ways, your sure it works fine and im sure that its the same as factory as it wont cut timing so lets move on with our lives.
divhunter is the next pfc user to try it on auto and he's in vic so i will have a look at his car. i will be interested to see the map tracer runs from it, ive asked for them a few times off people but never got them. i am more curious to see how as i want to understand how it varies over the manual setup. but no one seems keen to send them to me, so thats cool will see it when he has his pfc working.
Until its totally proven, no way am I puting a Pfc on my auto box.
I cant afford the 3-4k gearbox rebuild (sure perhaps in 5yrs time, but rebuild nonetheless)
dangerman4 - are you seriously suggesting that in 3,4,5yrs time youd be "surprised" if (or dare I say, when) the auto box goes bang?? I dont see how it can withstand your 300kw power figure for years on end without that ign.retard on gear changes.
meh.... Id like to run a Pfc as a piggyback option, but wouldnt know how to wire it up, so I wont :P
how can i show you my map tracer?
i had a look at it 10 min ago while my misses was driving. what would you like to know?
as it changes gears the load axis stays the same it just drops the revs to suit the new gear.
i will happily provide anything you require!
just let me know what you want me to do.
can u get a photo of it ? or plot it onto excel?
not good with excel never tried.
what will a photo tell you?
wont you need video to watch it move around the map?
pm me some more details and i will do it after work.
nah when you are in map tracer
press NEXT again and it will go in ghost trace mode
which keeps the cells highlighted on the screen for you
get a photo of that if you can
you can also press UP to pause the output
i have been real busy.
i will take a pic tomorrow for you and post it up.
As an independant observer, who doesn't own an Auto skyline, paul, do you think that if the timing was retarded during gearchanges it would be fine? wiring the auto"shift signal" to an aux input should be able to do it without too many dramas?
i went the safc 2 and the ITC path too, did alot of research and spoke to alot of people and as much as i wanted to put an fc in it couldn't bring my self to doing it, sure i would have got more power but i didn't want to jeopardise my gear shifts, as thats the only reason i wasn't happy with the car.
yeah, same as me - interesting to see your power output of 230rwkw, that'll be alarmingly equivelant to the approx. 200kw at the 4 wheel figure I expect after the next tune for my awd Stagea. Very similar mods too to the rb25det by the way :P
Was just in Darrens (dangerman4) 4door R33 auto with Pfc, with auto valve body shift kit. :(
For sure, a Pfc in a auto with shift kit, it certainly works. Changes are fine, and with his fatarsed turbo & engine work, it pulls damned well. Loads of power and an auto that is fine for a daily city-traffic driver.
Now it really makes me wonder about my next tune....! Keep with the piggybacks, or replace with Pfc, injectors and definately the MV Auto shift kit (this would be a must with a auto / Pfc combo), spend a 'little' extra and have a beast ofa Stagea - or not. :P
Sweet!
Was just in Darrens (dangerman4) 4door R33 auto with Pfc, with auto valve body shift kit. :P
Now it really makes me wonder about my next tune....! Keep with the piggybacks, or replace with Pfc, injectors and definately the MV Auto shift kit (this would be a must with a auto / Pfc combo), spend a 'little' extra and have a beast ofa Stagea - or not. :laugh:
Sweet!
And all on low boost!!
Cheers for the support fella.
And thanks for my first Stagea experience!
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
