Tuesday Night Dinner 5th Dec 2006
Tuesday Night Dinner on the 5th December 2006 will be at Castelli's at Indooroopilly (ph: 3870 2444).
**EDIT: The booking will be made for 7pm**
Castelli's is located on the corner of Clarence and Lamberts Streets, Indooroopilly. Car parking is available nearby.
Please RSVP (for yourself and your guests) by 2pm on Tuesday 5th Dec if you wish to come along.
Map is below.
Hope to see you there :ninja:
https://www.sau.com.au/forums/topic/145211-tuesday-night-dinner-5th-dec-2006/
  • Replies 70
Posted Images
LOL of course not...this is how you meet the best people :D
Tuesday night dinner crowd FTW :P
best might be an overstatement after the pub crawl
i saw whole new sides of you people.... it's so wrong and i love it
Ummmm Castelli's
You know how i feel about that place... IM IN without even checking the calander... :(
Ill try for Renee too, but no promiss's on that front...
OHOHOH Can we do the $15 all you can eat thing again???
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
