Items:
R33 Series 2 spoiler in KR4 sonic silver
Brand new R33 Aluminium brush looking Bezel for cluster (suit series 1 or 1.5 only) (SOLD!)
6 x NGK Premium Laser Platinium Plugs (PFR6A-11) suit RB26.
Item Condition:
Spoiler: Good working condition with some minor scratches.
Bezel: Brand New
Plugs: Brand new
Extra Info:
Not needed due to change of spoiler
Bezel doesnt fit series 2 cluster due to the uneven curve surround
Plugs: Didnt bloody fit my r33. bought from someone who claimed for r33 gtst
Contact Details:
either pm me or call/sms 0433 128 610
Price and price conditions:
Spoiler: $65 (SOLD!)
Bezel : $50 (SOLD!)
Plugs" $60
Edited by Giveitall
Items:
Item Condition:
Bezel: Brand New
Extra Info:
Contact Details:
Spoiler: $65
Bezel : $50
[/quote
Pic of bezel please also how do u tell if your skylines a series 1.5 cheers
for Bezel : basically all you need to check your cluster that it does not have circle surrounding on each warning lights and it should fit.
how much to central coast nsw
estimate around 60 to 65 buck.
dude i do advise that it 's not worth it cos it will cost as much as the wing itself. i am pretty sure someone from nsw will sell one soon. cheers
Edited by Giveitall
120 is still cheap if u can hold it for a cupple of weaks ill take it
from the way i am looking, it will not be sell anyway. if you got deal or business relation with transport company, feel free to use them.
Hey mate do u still have the wing? if so i am just after the LED in the wing i am prepared to pay just for that and do what you will with the wing also easier to send to me in NSW let me know thanks
John
I bought the Bezel, and it was well packed and in great condition.
Highly recommend to purchase off. Easy transaction. :(
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
