Car is 1990 R32 GTR
Power Mods 3" Turbo back zorst, Apexi Pods, Stock Turbos
Other Mods Suspension, Clutch, Aluminium Radiator
First run with stock ECU
Second run with Microtech LTX12 ECU, Bosch Coils and Ignition pack (only changes)
Was fairly surprised with result made 5 kw more with 4 psi less boost
and the 17 psi run, i was a little worried when he told me cause of stock turbos but they held no prob
Car now running 9 psi might turn boost up to 12 psi on weekend and leave it there
Boost isnt as smooth as i would like, but will prob get a Profec B-Spec II soon
All in all im quite happy, what you people think?
RellikZephyr
https://www.sau.com.au/forums/topic/145290-power-gains-from-microtech-comp/
Bloody difficult to compare when one is p and the other in kw. Those MX Dynos are happy in my experience, but not necessarily in this case.
That said you appear to have lost a bit of mid range with the low boost setting. I don't have a GTR but I wouldn't run it at 17psi on stock turbos if I had one. I think that 12-13 daily is fine.
What fuel are you using?
yeah as soon as i was told about the 17 psi i said NOOOOO and turned the boost down to 9 psi
i am running Shell V-Power 98 RON fuel
and thats why i modded the pic to include the KW reading on the HP chart
RellikZephyr
yeah the mechanic wasnt aware they were the stock ceramic turbos
luckily they held and if they didnt not my fault therefore he would have had to fix
but it has told me my stockers are in good nick
RellikZephyr
So your saying this guy will pay for your engine if it blows up when its on the Dyno ???
Tell us his details.. I bags the first tune. This guy is gona get real busy really soon.
RellikZephyr
if it blew because HE put too much boost into it
then damn right i would have made him
i never told him to set the boost that high
i had a EBC in there set to 14psi and it evendently wasnt set up quite right
so he put a manual boost controller on (to trouble shoot the EBC) and set the boost to 17 psi of his on decision
if it blew because of that and he didnt want to fix it i would have taken him to court
RellikZephyr
I would suggest its not the engine but the microtech. The resolution on those things is really poor. You just can't have a really good tune. They are great if the car is only going to run flat out (ie drag racing) but not very accurate with partial throttle and closed loop.
