im looking at getting my car chipped and tuned by my mechanic, i had a good look through sau about the power fc but i am unsure what would be better? i know the chip and laptop tune is cheaper,but would i benefit more from the power fc? are they hard to use or to find a good mechanic to tune one? im hoping one of u guys who use the power fc can help me out!
https://www.sau.com.au/forums/topic/145309-power-fc-or-piggy-back/
Yeah, they've discontinued the PFC's for the RB25's. Not sure on the RB25 NEO but I'm almost 100% that they use the same PFC as a R33 RB25. You can still pick them up but I wouldn't leave it too long
They have discontinued the Power FC for some models...... but the R34 is a different part number to the R33
Apexi Power FC 414-AN012 Nissan Skyline ECR33 RB25DET No longer in Production
Apexi Power FC 414-AN008 Nissan Skyline ER34 RB25DET No Longer in Production
Otherwise if you can pick up an PFC they are great!!
Mr Sniper911
Yeh definatly another vote for the FC here!, and there are many many people that can tune them............ just you need to find the right one that tunes them well! As Heslo said Shaun at Boostworx has done a crap load from here, and i'd say a crap load more from people not on here! Seems as the Power FC and Nissan are a quite the combo!
dont say there is no substitute for a Power FC this is just electronics... what is the alternate solution if they do not exist anymore. Alot of people would benefit from that sort of information.
Added bonus is that you can plug the PFC in yourself and drive to the dyno and get a tune.
The PFC isnt obvious, so there is a lot lower chance of a defect than having a SAFC mounted on the dash.
There are other options, but bang for buck and simplicity are in favour of the PFC
R34 ECU has self learning function, hence piggy back (SAFC) is not a good choice as it will return to basic ECU mapping after power cycle.
as the mapping developement will never be the same, a retune is require if the car run out of battery :(
i remeber Andrew is having such a problem with Unichip on his S15
Edited by Maxx
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
