Very nice Rod. For a stock VII, that sits very low. You also have a surround to the exhaust so possibly the previous owner has done a few bits and pieces? If it has been modified and need stock springs, let me know as I have them.
Mine retained the HID's too, they are ace. :)
  • Replies 76
Yeah I heard you had some troubles?
Although you're the first person I've ever heard having trouble after doing something like deca (ie. autocross)?
In the US, they only seem to break them after track day stuff, and even then, only after 30+ minutes.
There's a 8 MR on the stock gearbox running 9's.
Just watch 4th gear too Lowthy - it's made of glass :\
Yeah - uncle Jeff is investigating with Mitsubishi now. He's as confused as i am...
No teeth, just selector fork - seems heat was a problem. Will let you know more when I know :happy:
Uncle Jeff? Is that techsport?
Very interested in finding out the cause of this... So the gears themselves are ok, it's just the selector forks?
Cheers,
matt
are you guys all having kids or something and need the 4 doors!
seriously though I need a ride in one of these Evo's... I must be missing something, I just don't get excited about them... maybe once I have sampled the cornering goodness I will change my mind.... somone show me the light!
I be interested to know why the WRX boys have defected?
Just back on that gearbox issue...
Listed on the Ralliart website
http://www.ralliart.com.au/RalliartVehicle...nIX.aspx?item=2
the gearbox is listed as "6-speed manual (W5A51)"
I'm pretty sure the jap version gets the "MFA80" seen here
http://www.aichikikai.co.jp/english/mission.html
The only reference I can find to W5A51 anywhere is on this place
http://magna.trynsave.net/index.php?title=...amp;redirect=no
Nonetheless, interesting you've killed 4th and/or the selector fork.
Edited by poyz
James - Cool - thanks!
NickR33 - LOL - my Rexy was a 4 door! They're far more practical than a 2dr skyline! :happy:
Re: Rex boys defecting... Hardly... I had a 350rwkw R33 before I had the 05 Rex.. I bought this because it's the best new car at that price range... There's not a whole lot in it b/w the 07 STi and 07 Evo, the Evo (for me) was a more exciting drive.
Anything can be made to go fast in a straight line - it's the stuff between the straights that's the fun part! :glare:
Cheers,
matt
Edited by matlowth
Thanks for the info!
BTW - I wouldn't hold a lot of stock in the info on the mitsubishi aus website - a lot of that info is based on the EVO VIII they sold here previously (including the weight).
Interesting about the torque limit of the gearbox - considering they run over 400nm factory in Japan/NZ!
Cheers,
matt
Cheers,
matt
No worries Matt, by the way, you realise this is dandin (been a while mate).
I think I've seen you a couple of times at St. Kilda Towers, perhaps you can show me this Evo of yours sometime :glare:
Regards that torque limit, I'm sure it's underated. We all know the stock boxes can hold their own, I'm putting my money on driver error :happy::ninja:
Fark - No way!
You still got the GTiR?
Where abouts are you working these days?
LOL - Yeah - James IS a fair hack! :happy:
I think I've seen you a couple of times at St. Kilda Towers, perhaps you can show me this Evo of yours sometime :ninja:
Regards that torque limit, I'm sure it's underated. We all know the stock boxes can hold their own, I'm putting my money on driver error :glare::P
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
