Leatherette Gb#2 Orders
Jetdat
 Share
I so want in..
Before Im in Im Thinking either of these two setups..
R34 GTT Coupe 1998.. Black .. help me out here..
Black seats, Red stitching with red middle bits or ..
Black seats, Black stitching with cream/tan middle bits?
I like red but im afraid that if I get it on the interior panels such as the shifter and hand brake its going to be really bright .. Anyone got a pic of it?
  • Replies 562
Posted Images
hi, i really would like to place an order but don't no the colour codes for the leather. have looked for about an hour and still cant find any thing that can tell me what colour has what colour code.
can some one tell me what colour = code and which ones are wrinkle and non wrinkle?
moo1 = black...
m002 = ...
m003 = blue
m004 = dark grey?
and so on...
any help would be much appreciated.
thanks, loren
I so want in..
I'm in the same boat mate. I'm thinking two tone black with red double stitching.
A dark black outside with lighter black inside. I was thinking about a copy of the OEM seats but I saw some black leather GTR seats and they were HOT!
PACKAGE DEAL!
User: DECIM8
Car: SKYLINE R34 GTT COUPE 1998 - JUST WANT OEM STYLE
Front & Back Seats: BLACK - M001 (MAIN COLOUR [outside]), RED - M002 (SECONDARY COLOUR [inside])
PLEASE LEAVE HEADRESTS AS MAIN COLOUR M001
DOUBLE STITCHING IN EVERYTHING IN RED - m002
Wrinkle Front & Back: NO!!
Embossing Front & Back: Possable to get the skyline "S" embossed? in all seats
Door Trim, Centre Console, Handbrake Cover & Parcel Shelf, Gear Boot in: M002
Postage: Yes - NSW
DO NOT WANT: DO NOT WANT HEADRESTS IN m002 ONLY IN M001 - Rest of seat per normal
Thank you! Please let me know!
Edited by DECIM8
What if the call went out for payment by the due date or your out. Then see how many people there are, you should be able to negotiate with the supplier to see if they will honour the offer with slightly less orders.
The alternative is that we sit here doing nothing for another month, and then even after the order is put through I believe it is not a short process to have the covers made.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
