Leatherette Gb#2 Orders
Jetdat
 Share
  • Replies 562
Posted Images
i have spoken to Uitimate today i will send them an update list of all people who have paid.
they will in turn send the list back to me with payment confirmations. After that i will close this GB, it has gone on for too long and its not fair on the ones that have payed.
thanks everyone for the patience, but these are very much worth the wait.
deadline is when ultimate get back to me with the payed list..
but for exercise sake lets make it friday..
i apologise for the delay but you guys need to understand we made the deal with ultimate for 20 people, and in the EOI thread there was close to 20 people if not more that put their hands up..
anyhow i will let you know who payed and whe nthe covers should be delivered.
sorry for the hassle ive given u jedat....im just so upset that the idiots who said they were gonna pay still havnt.
i rkn someone should grab a list of ppl who said they are "interested" but have not paid.....and PM them to ask wats going on
User: GTS-T_Sedan
Car: 1989 R32 GTS-T Sedan
Front Seats: M001 (black) outside,M002 (red) inside with M002 (red) double stitching - headrest in m001(black) with m002(red) double stitching
Rear Seats: M001 (black) outside,M002 (red) inside with M002 (red) double stitching
Wrinkle Front: No
Wrinkle Back: No
Logo Embossing Front: No
Logo Embossing Back: No
Centre Console: M001(black) with M002(red) Double stitching
Handbrake Boots: M001(black) with M002(red) Double stitching
Gear Stick Boots: M001(black) with M002(red) Double stitching
Door Trims: M002(red)
Parcel Shelf: M001(black)
Postage or Pickup: Post
Pm sent about my order Jetdat
Cheers Nick
Hey guys, good news ... it looks like I might be back in ... :) Will know definetely soon. As soon as I know, I have the cash, I'll make my payment and put my order down again as it will change from my original one. after seeing the materials at ultimate auto trim.
Cheers,
Sam
I'm in and out more times than John Holmes (Porno Star - for those that don't know him). I am definitely out this time. My sale gell through .... no money .... I hope there is another GB, but looking at this current one, looks like it wont happen for a while.
All the best guys and many thanks to Jetdat for organising this. Common guys, get on the bandwagon and make this happen. I'm :P:laugh:;):) that I have to miss out.
Good luck guys.
This thread was dormant for like a week so I gave up checking, I get my system installed today and find out the dead line is in 2 days :S
Well I really want them .. still got that $400 set aside .. Ill see if I can come up with another $230
Id suggest pm'ing the others as I wouldnt have known if I didnt just spot the stain of ink on my back seat and remembered this GB!
Someone PM me when the nod is given to close it ill fwd cash at that point if I have it!!!
User: Loren
Car: r32gtr
Front Seats: moo4 outside moo5 inside
Rear Seats: same as front
Wrinkle Front: no
Wrinkle Back: no
Logo Embossing Front: yes
Logo Embossing Back: no
Handbrake Boots: moo4
Gear Stick Boots: moo4
Door Trims: moo5
centre console: moo4
Parcel shelf: moo4
Postage or Pickup: postage
277 Lindsay Road Buderim QLD 4556
paid for on 17th of jan.
User:DR1FT3R
Car: R33 GTST 2door coupe series 1
Front Seats:no
Rear Seats:yes - Colour: Black, with red double stitching.
Wrinkle Front:no
Wrinkle Back:no
Logo Embossing Front:no
Logo Embossing Back:no
Handbrake Boots:no
Gear Stick Boots:no
Door Trims: yes - Black
Postage or Pickup:postage
Money Required: $230 - made the payment on friday the 2nd of feb.
can you get bak to me when you received the payment JETDAT.
Cheers,
Joe
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
