hey guys just curious does anyone else see there gauge get this low? picture was taken about 5mins after i gave it a bit of a floggin thru 3rd and 4th and pulled up to idle...
oil im using is motul semi syn 10w-40w
Edited by l0WRB
https://www.sau.com.au/forums/topic/145360-oil-pressure-doesnt-look-good/
if you have a warning light too for low pressure then yeah its probably low low pressure = bad but if its just the guage it could be the sender on crack
im not sure ive never seen any engine light come on....its a late 94 series 1 r33....would it have engine light?
i done a compression test few weeks ago and came up basically 150psi in all 6 cyclinders few psi difference between them
Edited by l0WRB
yeah it would definetly have a light
from memory its top left, red light
turn the car to ON but don't start it (so diag/test lights come on)
and look for a red light with an oil tin can icon
could be anything. 1 bar at idle is a little low. the only real way to determine if it's a real problem or not is to get a hold of a proper oil pressure gauge. I would suggest buying one to have in your car permanently, but if that doesn't appeal, then just borrow one.
also, oil pressure at idle is not a major concern. I would be more worried about what the oil pressure is like at 3000rpm and 5000rpm.
yep just checked and it does have a oil light which is good! but i have yet to see it come on..im due for a oil change and concerned what oil to try...thinner or thicker? 5w to thin? stick with 10w? also i mite try putting a dif oil pres gauge on the car and check it thru that...do i do this wen its hot ?
sorry i didn't see what u wrote about the oil pressure at 3000rpm..it rises well above half way on gauge once i start driving it again but drops really quickly once i back off!
yes that is normal. pressure rises as revs rise, and falls as revs fall. the faster the engine is spinning, the faster the pump is spinning.
as long as it's over 4 bar at 3000rpm i would not worry too much. and yes, all readings should be taken when engine (oil) is hot. 10W40 is fine.
hahahhaa owned.. you sure showed them :)
was your oil pump faulty ??
i thought the same thing about my skyline when i first bought it...
"ah shes a little low on oil pressure, must just be the sender"
i said to myself
then BANG
my car did that once my turbo oil seal started getting worse, so it could be your turbo as well as worn bearings/faulty gauge. dont write it off as a faulty gauge without checking.
if you want to check if you've done your turbo oil seal then disconnect the piping at the lowest point of the plumbing and check for oil.
Generally when its the sender some days the oil pressure will be perfectly normal then another day it will read near zero or just low generally.
I've seen mine sit perfectly on zero, then just as I looked down it had a spazo and jumped quickly to 5 (~3000rpm) and was then perfect for the next week until it had another small spazo and began reading low again, then as usual it goes back to normal soon after.
If its constantly reading low I would be concerned and definitely get it checked. If its 'looks' like a stuffed guage get it checked anyway. :laugh:
Or buy your self a $100 oil pressure gauge and know your self for sure.
dude get a decent aftermarket guage on there. I WOULD be worried, but thats because i have had a low reading like that, and everything else was fine, no oil consumption, good power etc. but cost me $$$
your much better off if you rebuild the motor before it does any damage in the bottom end
Edited by HRthirtyone
well ive just done a oil change i used Penrite SIN 15w-40w wanted to go something a lil bit thicker..oil pressure hasnt gone below 1/4 and ive been given it a fair bit..seems to be running good.but im still pulling my hiflow off and gettin it all checked out seals etc.
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
