Hi
as u might know im looking for a GTR R32 but while i have been looking around ive come across a nice 1992 Twin turbo Toyota Supra. Jus wondering wot u guys think of them?
What are there performance lik compared to R32 etc etc
Edited by Adz2332
  • Replies 65
yeah, itd be a JZA80.
first things first, theyre pretty heavy mofo's, so they can be a bit boaty (2 of 3 that ive driven have had stock suspension, shocking stuff, the other had tein coilovers, massive improvement...)
they dont like to rev like the GTR's, but its much easier to make huge amounts of power from them.
theyre very comfortable on longer trips, takes a bit of effort to get in and out of, you sit in them rather then on them, if you get my meaning.
theyre thirsty, and theyre not the easiest things to drive in the wet, but all round, theyre great cars, and i doubt youll regret buying one.
The 2JZ engine was in the 1993 - onwards (the 96/97 + models came with VVTI i believe). It can be either NA or twin turbo. The main difference is the power and the weight (if you are comparing to the R32). r32 gtst has 160 kws and 290nm torque? , where as the JZA80 twin turbo has 206 and 430nm torque. But the supra weighs a lot more than the gtst. 0-100 in the supra is said to be about 5.6, where as the gtst is in the low to mid 6's.
Both engines are durable - strong internals, revvy. Supra twin turbo in manual comes with an extra gear. But down sides, supra has no space at hte back. The r32 i think has more space in the back.
EXCELLENT GUYS. Does anyone kno wot the model letters mean lik supra SZ or RZ?
if the car youre getting is an RZ or an SZ its a'93-'02 (JZA80). anything before that (to '86) is the JZA70.
afaik, RZ denotes the turbo/twin turbo models, and SZ is the non turbo.
Edited by scandyflick
if the car youre getting is an RZ or an SZ its a 93 onwards.
So i should be looking for a RZ 2JZ engined Supra??
I have had a look at 3 cars so far, would these figures i have be about right for each car?
1993 Supra 13.1 1/4mile 320hp standered
1989 GTR 13.0 1/4mile 280hp standered
2000 WRX 14.4 1/4mile 227hp standered
*Standard...
forget the rex. glass gearboxes arent cool.
the supra has the advantage of being newer, and being able to make power easier than the GTR.
the GTR afaik is lighter, has the advantage of AWD, and is just plain cool. :)
Yup, look for a JZA80 RZ with the 6 speed manny.
jap spec RZ is only 280hp - but this is disputed (similar to the gtr). US and british spec RZ is at 320hp
Better to go with the RZ - should you wish to do mods to it. SZ is ok - but when it comes to mods, you are restricted imo - and installing a turbo is not as easy as it sounds (or so i hear)
not to mention they got steel wheels on the turbos... *sigh*
Also to mention that PARTS as in modifying parts are alot more expensive, as there isn't as big of a damand for them as there is Nissan parts!
I thought of getting a Supra before i bought my 33! I am thankful for getting the 33!
Edited by Deluxe
but the flip side to that is that you dont need to open up the engine when you start chasing big horsepower like youd have to with a nissan engine.
But i hear nissan GTRs r hell exspensive to fix! Supras r much cheaper for every day parts? this true
try to get your hands on the special issue (i forget what number it was, but it had a pic of a blue s15 in the front) of speed magazine that gave mods for supras - that will show you roughly howmuch u can spend on mods depending on the different stages.... plus it had comparisions of the rz, gtt, s15 and rx7 as well....
just saw this while searchign for the issue of speed that had supras in it:
any car is expensive to fix where parts are concerned - best to get one where parts are plentiful
In the comparisions of the rz, gtt, s15 and rx7 which did they believe to come out on top?
Is it a new mag will it still be instores?
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
