Hi all, it's been a fair while since I've been on here or for that matter anywhere near my car. Basically wanting to sell it as I work long hours so I simply don't have the time and energy for the attention it needs.
It does need a little TLC, nothing too serious. It has had the cylinder head replaced about 6-7 months ago and it hasn't been driven since i got it home so I definitely will need the head re-tensioned and that's why it's blowing just a little bit of blue smoke.
Apart from that it runs pretty good. I haven’t fired it up in about a month so I'd say the battery is probably gone flat.
Other little problems are a small dent in the drivers side door, and someone ran up my arse and so the right rear light is cracked and a little dented, but nothing too serious and not really all that noticeable. Apart from that the car is pretty much immaculate.
Have a full service and rego history spanning something like 10 years or more (I'll have to dig that out, I know it's somewhere in the living room :) .
It's got roughly off the top of my head about 250K on the clock (but I'll confirm the exact K's when I get home tonight).
It's Silver/black two tone. It's a series 2 but has series 1 rims. Happy to email pics to anyone, just email me.
Rego is until the later half of January 07.
I'm looking for $2K flat. The car is in Neutral Bay in Sydney.
I'm contactable on either 0400036014
or [email protected]
If you are interested, please remember the car isn't running too crash hot due to it needing the cylinder head retightened so the best bet is to either drive it to a mechanic that’s close by (I can recommend a few good ones in the area, or have a tow truck).
Oh and it has been garage the entire time that I’ve owned it, and judging by the condition it was garaged for most if not all it’s life.
Any questions, feel free to contact me.
https://www.sau.com.au/forums/topic/145374-1982-nissandatsun-280zx/
I'll try and get some better and more curent shots up over the weekend, these are the ones i have at work.
Sorry about the latness of the pics flip.
blk180, email sent.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
