stuartlaw_78 Posted November 30, 2006 Share Posted November 30, 2006 Hi all, Got an R33 Turbs... I've rebuilt the engine and put in an Exedy clutch, etc... forgies and all the rest of it... the problem I'm having is at between 1500rpm and about 1800rpm under a bit of load, I get this nasty vibration that shakes through my car. I can feel it on my foot but not so much through the gear stick. It the same noise that you would get if you had 2-3 heat shields all loose!! I've been told things like, timing, drive shaft needs balancing, etc.. I've checked every freakin nut and bolt and can't see anything loose! Any ideas???? Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/ Share on other sites More sharing options...
RaseR Posted November 30, 2006 Share Posted November 30, 2006 (edited) Hi mate, I've got exactly the same thing - funnily enough I've got an exedy clutch in there as well, and searching this forum has netted a few other exedy owners who've had similar issues in the past...hmmmmm. Wish I could definitively tell you what causes it, Nissan had a look at it for me when I had my major done last week, they agreed that it was the clutch or drivetrain, other ppl have also mentioned tailshaft specifically (not being indexed correctly or something?)...... Edited November 30, 2006 by RaseR Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-2718147 Share on other sites More sharing options...
stuartlaw_78 Posted November 30, 2006 Author Share Posted November 30, 2006 hhmmm..... very interesting. I can't see why our Exedy clutch's would caus this. I had everything balanced and I tourqued everything up to spec... very weird... This is killing me here... It has to be the drivetrain, surely... Another question for you, do you get any other weird noises that seem to be clutch or tranny related?? Like a bit of a low pitch whining noise on idle? My car runs like a dream but these noises really bug me... If there is anybody out there who had the same problem, expecially if you have an Exedy clutch, please let me know... this is an issue and it needs to be sorted.. Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-2718820 Share on other sites More sharing options...
RaseR Posted December 2, 2006 Share Posted December 2, 2006 (edited) Hi mate, Check this thread for other ppl experiencing the same thing: http://www.skylinesaustralia.com/forums/in...howtopic=143714 I don't have the whining noise you mention, but I do have another clutch related noise - a lovely chirping sound (sounds like a cricket!) most likely caused by either a worn thrust bearing or input shaft bearing, goes away as soon as you push the clutch in.........Why didn't the previous owner have this replaced when they did the clutch??!!?! It's like a 90c part or something ridiculous like that. ...Hope someone comes up with a solution! Edited December 2, 2006 by RaseR Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-2721502 Share on other sites More sharing options...
stuartlaw_78 Posted December 2, 2006 Author Share Posted December 2, 2006 Hi again, thanks, I'll check it out.... just quickly, you mentioned that you have that cricket noise? I also have that but I did replace my thrust bearing... it's freakin weird... would you believe that I couldn't get the input bearing out!! That's probably what it is... dunno.... if you have any luck finding out what your vibration noise is, lemme know... I'll do that same... I'm starting to think it's a balancing or timing issue.... Cheers.... Hi mate, Check this thread for other ppl experiencing the same thing: http://www.skylinesaustralia.com/forums/in...howtopic=143714 I don't have the whining noise you mention, but I do have another clutch related noise - a lovely chirping sound (sounds like a cricket!) most likely caused by either a worn thrust bearing or input shaft bearing, goes away as soon as you push the clutch in.........Why didn't the previous owner have this replaced when they did the clutch??!!?! It's like a 90c part or something ridiculous like that. ...Hope someone comes up with a solution! Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-2721608 Share on other sites More sharing options...
Kinks Posted December 3, 2006 Share Posted December 3, 2006 it's not just bearing noise is it? RB motors are designed to be loaded at high revs, not low revs. Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-2722566 Share on other sites More sharing options...
RaseR Posted December 3, 2006 Share Posted December 3, 2006 Hmm, doubt it - my old R32 never did it...Unless it's an RB25 thing? It really does sound clutch/drivetrain related IMO. Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-2722579 Share on other sites More sharing options...
ookami Posted December 3, 2006 Share Posted December 3, 2006 I've seen this problem with other cars before (S13 and R33 GTs-t) and both times it was because the clutch was not balanced properly and at that engine speed it would vibrate the hell out of the exhaust brackets that bolt onto the gearbox. Try removing them and see if that helps otherwise get a better clutch Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-2722822 Share on other sites More sharing options...
stuartlaw_78 Posted December 3, 2006 Author Share Posted December 3, 2006 thanks for your input mate but i think I'm about to blow your possible theory out the window because my exhaust isn't standard and doesn't actually touch or bolt to the tranny at all. is that what your talking about? Just trying to clarify because what you say about the clutch makes sense but if that isn't balanced properly, then where else could the vibration be coming from? Thanks again, if you have any other ideas, let me know.. I want to solve this problem but if I'm going to drop the gearbox, then I want to make sure I'm not wasting my time... I know it's guess work... sucks... I actually had my clutch balanced after I brought it from the same place that balanced my other parts.... I hope I've put it all back together properly and there isn't a bolt shaking loose!!! I tourqued the bolts up to spec so they should be fine.... I've seen this problem with other cars before (S13 and R33 GTs-t) and both times it was because the clutch was not balanced properly and at that engine speed it would vibrate the hell out of the exhaust brackets that bolt onto the gearbox. Try removing them and see if that helps otherwise get a better clutch Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-2723307 Share on other sites More sharing options...
EvilINGT Posted December 3, 2006 Share Posted December 3, 2006 Strangely ive got the same prob. The lovely chirping from the clutch when in neutral and as soon as you even slightly load up the clutch it goes away. I also had the thrust bearing replaced as it was provided with the new clutch/pressure plate. Anything under 2k revs in 3rd gear provides the vibration, but not sure if thats just the engine having to much load on it, or the diff as i have a standard diff which clunks at low speed and can make the car 'hop' if the weight shifts front to rear. Im thinking for me either diff rebuild/new 1.5way or new clutch nismo/excedy. Either way my final 250rwkw power goal will be better served with these other mods i guess. cheers Evil Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-2723575 Share on other sites More sharing options...
stuartlaw_78 Posted December 12, 2006 Author Share Posted December 12, 2006 Hi guys, An update, I took my car into a workshop to get some new tranny oil put in.. It seems to have made the vibration a little bit better but not much. The guys there seem to think it's coming from inside the transmission. My tranny is old and they said something about the bearings needing replacing so I'm now looking for a good tranny, hopefully from an R34! I will have to find out if they are compatible. Does anybody know if they are??? Strangely ive got the same prob. The lovely chirping from the clutch when in neutral and as soon as you even slightly load up the clutch it goes away. I also had the thrust bearing replaced as it was provided with the new clutch/pressure plate. Anything under 2k revs in 3rd gear provides the vibration, but not sure if thats just the engine having to much load on it, or the diff as i have a standard diff which clunks at low speed and can make the car 'hop' if the weight shifts front to rear. Im thinking for me either diff rebuild/new 1.5way or new clutch nismo/excedy. Either way my final 250rwkw power goal will be better served with these other mods i guess.cheers Evil Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-2745930 Share on other sites More sharing options...
EvilINGT Posted December 15, 2006 Share Posted December 15, 2006 Ive had redline lightweight shockproof put in the gearbox and redline gearoil put in the diff. Still suffers from the same probs 1500ks later . cheers Evil Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-2752692 Share on other sites More sharing options...
R31_GTSX Posted June 13, 2007 Share Posted June 13, 2007 Just came across this thread in doing a search.. I have the exact same problem as described... R33 Series 2 RB25DET with 5 speed second gear at low speed acelerating 1800 - 2000 revs. I'm unsure wether its standard or heavy duty, feels light & very easy to drive in trafic. Has anyone on this post found their solution? Its bloody annoying! Would love to know. Cheers Travis Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-3176228 Share on other sites More sharing options...
MotoMan Posted June 13, 2007 Share Posted June 13, 2007 Have the same problem... im having my gearbox fixed soon.. (bearings, synchros, seals, clutch) will update if the noise goes away.. Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-3177741 Share on other sites More sharing options...
joeyjoejoejuniorshabadoo Posted June 14, 2007 Share Posted June 14, 2007 i have an aftermarket single plate clutch and i get the noise too... (but its barely noticeable, i.e. only when i'm in the driveway next to a brick wall) put my foot on the clutch and it goes Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-3178426 Share on other sites More sharing options...
MotoMan Posted June 14, 2007 Share Posted June 14, 2007 i have an aftermarket single plate clutch and i get the noise too... (but its barely noticeable, i.e. only when i'm in the driveway next to a brick wall) put my foot on the clutch and it goes thats not the noise we are talking about... its a full on shudder between 1500-2000rpm while accelerating Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-3178478 Share on other sites More sharing options...
Kinks Posted June 14, 2007 Share Posted June 14, 2007 full-on shudder sounds like tailshaft issues. mine sounds like bearings whirring if you try it from too low revs. RB's aren't designed for high load at low revs. get a diesel. you are all driving in too high a gear, like bimbos who crawl up hills in 4th with their engine pinging its tits off. change down. Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-3179600 Share on other sites More sharing options...
Rekin Posted June 15, 2007 Share Posted June 15, 2007 Not sure if its the same thing, im in 1st gear, rev to about 1000-1500rpm and slowly release clutch just above friction point. Car starts to wobble feels like left/right and feels like its going to stall but revs are at 1000+ let go more of clutch and accel and the wobbleness goes away. Spoke to a gearbox/clutch specialist, said that the flywheel could be out of balance. Does my problem sound anything similar to yours? Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-3180459 Share on other sites More sharing options...
joeyjoejoejuniorshabadoo Posted June 15, 2007 Share Posted June 15, 2007 thats not the noise we are talking about... its a full on shudder between 1500-2000rpm while accelerating yeah, i know... replying to this... I don't have the whining noise you mention, but I do have another clutch related noise - a lovely chirping sound (sounds like a cricket!) most likely caused by either a worn thrust bearing or input shaft bearing, goes away as soon as you push the clutch in Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-3180489 Share on other sites More sharing options...
shadow21189 Posted August 24, 2016 Share Posted August 24, 2016 hi just came across this thread. ive just fixed this issue.. same deal replaced clutch went an extreme single plate button DSB type clutch and had this annoying vibration. I'm a mechanic myself and didn't want to believe that a bras would generate this bit of virbration. luckily for me I have a 4 post hoist at work so threw it up and had a work mate load it up and found my passenger engine mount had broken as well as my driver side had horribly sagged threw 2 new engine mounts in and whala BEAUTIFUL!!! also added an engine steady dampner bar to help prolong the life of the mounts as well direct the engines tourque to the drive line a bit better 100% worth the $$.. well this fixed my issue so perhaps its something you guys should look at good luck =) Link to comment https://www.sau.com.au/forums/topic/145394-weird-vibrationnoise-on-low-revs/#findComment-7769481 Share on other sites More sharing options...
