For sale unwanted gift need cash for Christmas, this laptop is brand new in the box with all Software etc... + warranty. Will beat anyones price
price RRP A$1,329
Click here to see how much it cost on Ebay
Click here to see how much it cost at Dell.com
Selling for $1000 or near offer willing to negoiate.
located in Sydney CBD
Versatile Entertainment
The Inspiron 6400 was designed with versatility in mind. It incorporates Intel® Centrino® Duo mobile technology and Genuine Windows® XP Professional or Genuine Windows® XP Home Edition to provide wireless connectivity anywhere wireless access is available and improved battery performance versus its predecessor. Thanks to the combination of Intel 945® mobile chipsets and low power consumption Intel® CoreTM Duo Processor, you don't need to compromise on battery life if you want to enjoy your multimedia or productivity applications away from home or in the office.
Inspiron 6400's 15.4" wide aspect displays and the brand new Intel® Media Accelerator 950 graphics technology all combine to provide a superb visual experience.
The eye-catching, stylish Artic Silver and Alpine White design incorporates a 5-1 card reader as well as front-access multimedia buttons for conveniently controlling audio CDs or movies. Even connecting all your digital multimedia devices is easy with the Inspiron 6400. It comes with a standard S-Video (TV-Out) port, IEEE 1394, and four built-in USB 2.0 interfaces.
The Inspiron 6400 also features the next generation ExpressCard card slot for connecting various expansion devices (ie. WWAN ExpressCards, TV Tuners cards - items sold seperately) - please note that this model does not support the older PCMCIA Interface.
Mobile computing has never been easier!
Processor: Starting from Intel® CoreTM Duo T2300E (2MB Cache, 1.66GHz, 667MHz FSB) with Intel® Centrino® Duo Mobile technology
Operating System:
Display: Wide area with the 15.4" Wide-Aspect display. Choice of standard WXGA or optional UltraSharp WXGA and WUXGA with TruelifeTM LCD Displays
Chipset: Intel® 945GM
Memory: Up to 2GB dual-channel 533MHz or 667MHz DDR2 SDRAM provides blazing performance.
Wireless: Internal PCI-e Mini-Card WLAN support; Optional Internal card with Bluetooth® wireless technology
Storage: Up to 100GB (5400rpm) SATA hard drive lets you store and access abundant data on your notebook.
Media Bay Options: Configurable DVD/CD-RW or DVD+/-RW optical drive.
Edited by r33zilla
https://www.sau.com.au/forums/topic/145425-fs-laptop-dell-insprion6400ma/
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
