Watup g dogs,
had a set of d2 s13 coilies on my ceffy now for yonks.
had them installed by pedders, no bull! and they said they wound them up as high as they can go and the car was only cms from the ground.
anyway, iv put up with it for months and months now and iv decided to ask the question:
if you have d2 s13 coilovers on your taxi, can they be wound up any further or do u have the same problems?
Cal.
(Grove St. 4 Lyfe!)
https://www.sau.com.au/forums/topic/145426-lowness/
The problem (more of an advantage IMO :D ) is stock S13 struts are shorter than C33/A31 to begin with, wich in turn means your ceff will be lower than a s13 when the coilovers are set at any given height.. I wouldn't trust pedders word btw, they specialize in putting king springs in VL commo's.
https://www.sau.com.au/forums/topic/145426-lowness/#findComment-2718365
whats the problem? front or rear?
IF they are base adjustable?
for front
jack car up
wheel off
crack the locking ring
undo 2 bolts at bottom of strut
and wind the base to make the strut longer
for rear
almost exactly the same, except there is only one bolt at base of strut
(there is another way to do it by simply cracking the base of the locking rings, and using a c-spanner to adjust, but unsure of your knowledge and how good my explanation would be; so this way (above) may be easiest to do.)
IF they are not base adjustable, and height is adjusted by changing the preload of the spring simply use the C-spanner on the locking rings to adjust (lengthen/shorten) the coilover rideheight. You do not need to undo any bolts, just remove the wheel.
good luck :D
https://www.sau.com.au/forums/topic/145426-lowness/#findComment-2718589
yeah - that sounds similar to mine at the back-end of the car... the locking rings are as high as they will go at the moment, and my car is sitting really really low!
I reckon that being so low looks good, but I do have problems since I can't get over the speed-bump into my apartment complex without the car bottoming-out, and the last time I went to the drive-through carwash I got stuck! :D
Edited by AlcoholicA
https://www.sau.com.au/forums/topic/145426-lowness/#findComment-2718715
Yonks? Peddlers? what?
if there as high as they will go and for some odd reason you want them higher you might want to try to locate a set of helper-springs.
stick a set of these in there i had the same problem... good to go now... running 12k and 10k shorties on S13 JIC's incase your wondering...
Edited by 4DoorWhore
https://www.sau.com.au/forums/topic/145426-lowness/#findComment-2719292
my ISC's and my old HSD's were both S13 type and the car was low, but never had the problems you guys are talking about, so maybe just suss the adjustment.
if its base adjustable
set your preloads as much as you can by hand then use the C spanner to tighten it up a little more. this way the spring wont be loose over bumps etc. you dont wont it too tight, otherwise it would not be serving the purpose at the actual spring rate. (eg 8kg spring overtightened 'may' be more like 12k etc...).
then measure up make sure other 3 are the same preload, and then adjust the base for the height.
simplest way is to start from scratch with all 4 of them out. that way you can measure each one has the same preload and the height adjustments are the same.
if you want me to talk more just ask :)
https://www.sau.com.au/forums/topic/145426-lowness/#findComment-2721009
hey huddy, common misconception about the preload there. an 8kg spring wound up 1mm or 100mm on preload is still an 8kg spring, as it takes the same amount og force to move it 1mm or 100 mm. the rate of the spring does not change.
All its for is as you said, keeping it captive.
https://www.sau.com.au/forums/topic/145426-lowness/#findComment-2721580
yeah but if you wind the f**k out of it, (as i had to do with some tanabe coilovers which weren't base adjustable in the sil80) the spring isnt slightly compressed, but instead its hugely compressed; giving it less room to expand and close... therefore it isnt working how it is intended (for that rate) as it is in a smaller area.
just what i'm thinking in my head anyway :S
edit*** - yep simon knows what i mean so i'll add this if anyone gets confused
i didnt mean you can adjust spring rates by more preload.
Edited by huddy
https://www.sau.com.au/forums/topic/145426-lowness/#findComment-2721941
    • Knowing how slow their other compressors are that connect to the cars battery, you'd want to hope it's one hell of a slow leak!
    • So why can’t the front pipe just be listed as custom make? why does everything have to have a brand name to it? or if you have bought the car like this and have no idea about anything at all or no knowledge what so ever of parts how are you supposed to inform them of what it is you have exactly?
    • Yep, I'd be interested to hear how it works out in the end.
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
