  • Replies 145
zomg thats almost as bad as the s2000 2jz conversion.. least that was an improvement
this on the other hand is death. altho would make it easier for big turbo conversion having the inlet on the same side as the brake booster n shit on the lhs when converted....
but still this is a sin that will send anyone straight to hell. arabs n all shit, i dont care
all it needed was a hks rb28 kit n would kill any 2jz
RB26>2JZ
not 2 mention a shit load of oil/petrol
U.A.E Will be the first country to run out of oil, Hence why they have tried to turn it into a business and trade hub.
Petrol here isn't as cheap as most people would think.
In Saudi on the other hard, I pay 15cents a litre! Now that is hell cheap!
Cheers
Josh
i wouldnt mind it so much if they worked a miracle and kept the awd, then atleast i could live with it, respect the 2jz
admitedly pointless if your going for this sort of setup maye aswell of replaced a 25t, that would be meaningful atleast !@
love the Top Secret TE37s, but those fenders are horrible. even if the style is not to my taste (which it's not) at least they quality could have been good, but it's terrible. The engine work also looks like arse, but the idea does have some merit and if it runs well will be quite fast. considering the car was possibly stolen in japan and sold to someone in UAE for $10 or $20K then it's not a bad way to build a cheap fun car.
still such a butchered car by now considering the LHD conversion, the dodgy kit and the engine swap. :ninja:
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
