Oh another thing, I personally don't like cross brand engine swaps, for absolutely no legitimate reason. I just don't like it.
Personally I'd love to get ahold of an S15 or late 180sx and do an RB26 swap into one when funds allow, and keep it all stripped out as a dedicated track car.
Dan.
So whats the reason ur T51R isnt making 800-100hp on ur 2J? I mean whats the point of 800hp+ worth of turbo for only 500ish???
  • Replies 145
Ran out of injectors and reached the flow capacity of the 33 GTR cooler I had at the time. Will be back on the road soon with 1000cc injectors, greddy 4-row cooler and virtual works intake manifold.
My view on it is I wanted to buy the turbo for my final goal, then work towards it, not waste money on US turbo's, or a smaller turbo, and then upgrade again later on. Going the other way first, and upgrading everything but the turbo with my stock turbo's would of produced a pretty un-inspiring product in my mind. I personally don't like sequential turbo's.
Dan.
You didn't actually read my last two posts did you? Try reading the one before that, and re-think your comment.
Also the ultimate circuit car is a stripped out dedicated circuit car. I enjoy my creature comforts far too much to have my Supra head that way.
Dan.
Actually i did and you seem to be changing your mind like undies
Well how about the fact I never said I'd put a T51R or something similar on this particular car? Why be an idiot about it and try and twist my words? In what way would an RB26 with a properly sized turbo have too much lag?
Dan.
Guest
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
