and Ian, you didn't want those tyres back did you?
They will be wearing well now... chirp chirp :)
Nah :) Glad you got some fun out of them!
I'd be interested to here from the guys with the stagea series 2 triptronic gearbox (if they install one of these) as in my R34 (which is 200kg lighter than my manual stagea) I have no trouble with it changing gears - so I don't know why the stagea version would be too slow..
Ian
Ian
It probably depends how picky one is about how long it takes to change gears. I have no doubt there is no difference between r34's and s2 stageas as far as this goes. Its a matter of what you are used to and maybe how the transmission has been treated etc.
In my case the trans would change gears without any trouble at all but changing from 1st to 2nd at high revs would take a bit longer. That was my reason for getting the shift kit and I'm very happy with it now. Shifts are very close to being instantaneous.
However there is no "fault" with stock s2 stagea tiptronic gearboxes as such. I just prefer the quicker, sharper shift.
Anyone living in SA, dont bother fitting it yourself - just take your car into MV Automatics in blackwood. I paid $440 to have it fully installed by them. I just left my car there for the day. That price also includes a transmission service (fluid replacement) so its definitely good value. :(
On the other hand, if you're happy with the speed and quality of your shifts then there's probably no need for a shift kit.
Yep, could be that I'm older and don't need the fast changes anymore.. :thumbsup:
In the R34 the down shifts are almost instant, the upshifts take about .5 sec. But with the range of the engine torque I just don't notice given my normal driving...
It probably also helps that the R34 is 200kg lighter than the RS4S - and that is noticable as even though they have the same engine/turbo/intercooler the R34 seems more snappy than the stagea (even though it is a manual) as long as it isn't wet (where the R34 back wheels will just spin so easly if I turn traction control off.. :laugh: ...
I have had a shift kit fitted by a motorsport workshop in Brisbane. It certainly does make gear changes a lot quicker 1-2nd churp at only half throttel. I put it in for use at the track more for the down shift than anything elce. But it has started to play up when changing down from 4th to 3rd it grabs 3rd then releases grabs then releases. It does this until you drop down to about 70K. I have had it back to them but they don't know why it is doing it. If it is left in drive it seems to work ok up and down the gears. I was also told not to be in 4th under 80K is this right or are they blowing hot air up my A##.
Sounds pretty good mate, i might have a chat to the fellas at MV Automatics next time i'm down that way. Been considering this upgrade for a while now.
Sounds like they think your Stagea is a VN Dunnydoor. :P
The VN's would prematurely burn out their trans (as word has it from when they were cabs) when running around the city in overdrive as the auto would change in to it too early.
Alex.. I've watched your vids on youtube and it looks/sounds as if its flaring a touch on the 2nd to third change.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
