I've just found out my wife is pregnant with our second child so am considering selling my car for the right offer. I've spent over $40K on it this year alone and could do with getting some of that back before the new bub arrives next year.
It's a 1999 V Spec - 50,000km's - however it's currently done less than 500km's since a full rebuild including new block, rods, pistons, crank and balancer.
The car has been set-up specifically designed to be fast as it can for tarmac rally / touring rally / circuit racing. Pretty much other than a carbon-fiber prop shaft it has exactly the same goodies as the famous Mines R34 GTR including turbo's, cams and diff's.
It's currently making 362rwkw's @ 25psi on pump fuel (BP Ultimate). I'm the 2nd owner and have had the car since mid 2003. I'll consider offers around the $100K mark.
Mods include:
Engine
RB26DETT
Aria Forged Pistons
ARP Rod Bolts
Eagle Forged Rods
Tomei Metal Head Gasket
Tomei 260-9.15/260-9.15 intake and exhaust Poncams
Tomei Fuel Pump
Racingline Adjustable Cam Gears
Ross Tuffbond Harmonic Balancer
Sard 700cc Injectors
Apexi Dual Intake Pods
N1 Oil Pump
N1 Water Pump
Apexi Front Pipes
Blitz NUR Spec Exhaust
2 x HKS 25/30 Turbo’s
Trust Intercooler
Race Aluminum Radiator
Serck Oil Cooler with remote filter
Racepace Catch-can.
Handling
HKS/Dynamic (UK) remote reservoir racing suspension
King Springs
Whiteline Heavy Duty Sway Bars (front and rear)
Racepace custom upper control arms
Nismo Lower control arms
Cusco castor rods
Pineapples
Hicas Lock Bar
Driveline
Getrag 6 speed gearbox
Jim Berry Custom Twin Plate Clutch
Racepace modified Attessa system
Nismo 2 way rear diff
4.111 front diff
Wheels and Brakes
Rays Nismo LMGT4 rims (Bronze 18 x 9.5)
Toyo R888 tyres (255/40/18)
AP Racing CP5555 6 Pot front calipers
375mm Alcon Rotors – Ferodo DS3000 pads
Brembo Rear Calipers
DBA 4000 Rotors – Comp 2 pads
Cusco Master Cyliner Stopper
URAS Competition Handbrake Shoes
Electronics
Autronic SM4 ECU (including Launch Control, Anti-lag, Flat Shift etc)
Autronic R500 CDI
Nismo MFD
HSK EVC 3 Boost Controller
Raceworx Attessa Controller
Orange TPMS
Interior
Nismo 320km/hr Dash
Nismo Titanium Gear Knob
ERG 4 point harness
Eclipse CD/DVD player
Boston Rally Splits
https://www.sau.com.au/forums/topic/145478-r34-gt-r-v-spec/
As someone with two young one's the second is a lot cheaper. Keep the car, I reckon that you will regret selling it, and you probably won't get a chance to get another like it till the kids have moved out.
https://www.sau.com.au/forums/topic/145478-r34-gt-r-v-spec/#findComment-2721658
Congrats Andrew, hope it all goes well for you.
with the spare money you have from selling the car, purchasing a new one and spending money on the bub i hope you've had some financial planning and that u have money working for you
https://www.sau.com.au/forums/topic/145478-r34-gt-r-v-spec/#findComment-2722771
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
