Guest RedLineGTR
no most r33 dont come with ones maybe some series II & GTR version might have ones from jap factory fitted. On the alarm depends how big your wallet is you can get car alarms with an enigne Immobilizer for like $100 you can also purchase ones for about 2000$ so check you pocket, also a good idea to check you insurance if they would give a discount on fees for a specific alarm system. Also try a search on good on car alarm reviews you'd be suprised in what you find out. Hope it helps. Rob
https://www.sau.com.au/forums/topic/14549-immobilisers/#findComment-294560
haha! ...but we all knew what he meant, right?? :D
gtssky, I've got a Brant AA02 alarm/immobiliser.
also got it so I'd have keyless entry! :(
it cost $595 fitted....although that was 2 years ago, might have gone up by now. That cost includes them coming out to fit it at your work/home.
have a look here: http://www.brant.com.au/html/show.htm
https://www.sau.com.au/forums/topic/14549-immobilisers/#findComment-296386
the brant nemesis cost me like $850.
it's got a 6pt immobiliser, key pad (need to put in the pin before the car will start) and keyless entry.
i think it uses the AA02 immobiliser + remote fob that shell has, with some cannibilised parts from other brant alarms (such as the keypad which can also be bought seperately)
https://www.sau.com.au/forums/topic/14549-immobilisers/#findComment-296599
    • Very true, if buying new, I would not get an PP either. Minimum is an Elite 2500, which is also considered outdated. Get something that supports DBW, delete that cable throttle. Best thing I've ever done to the Skyline, next best is refreshing the A/C with a new condenser. It's cold, but not as cold as modern car, but colder than most 90s JDM shit boxes imported into Australia.
    • Haltech have a nice comparison table between the Elite and Nexus models -  https://www.haltech.com/ecu-buyers-guide/ In general, the Nexus is better. Haltech have some nice product videos on their YouTube page, I'd have a look at those and if you're still not confident what way to go, I'd give them a call. They have the best customer support of any company I've dealt with, I'm sure they'll be able to help you out.
    • Not to mention, that the correct diagnostic approach to "electrical thing does not work" is to start with what I outlined above. You only do swaptronics for things that can't be tested really easily, like ignition coils, AFMs, etc etc. And even then you hold your breath in case the fault that possibly killed the original unit kills the swapped in unit too.
    • Unfortunately man I don't think there's much here. You may very well be the only person to ever interact with/modify/have to un-modify that wiring. I was once selling a stalk. Due to how Nissans Nissan, the indicators and the hazards are on the same circuit. if you don't fully plug in the hazard switch, the hazards will work but your indicators won't. People then go looking for indicator stalks, but the issue is the hazard switch not being plugged in fully. That is the entire encyclopedia of R34 indicator knowledge lol
