everything needed to convert your vl into a vlturbo minus the computer and injectors which can be readily available from ebay+ calaisturbo.com.au for a few hundred bucks.
heres whats included, possibly more that ive forgot to add. t
turbo manifold with garrett 42mm wastegate welded ontop and screamer pipe
garrett t3/t4 highflow turbo, some shaft play, could possibly require rebuild
t3 turbo no shaft play however the fins are worn but turbo spools and produces boost perfectly and very quickly, has a very mean dose!
braided oil inlet line with speedflow fittings,
oil return line and fittings
some water lines aswell
standard dump pipe
standard vl turbo front pipe (pipe from dump to cat)
gutted cat "highflow"!
standard vl turbo cross over pipe
custom pipe from inlet of turbo to air flow meter 3 inch to suite the t3/t4 turbo
air flow meter
vl distributor+coil
$1000 no offers not separating, so please dont ask!
please PM me on this site for information, pics will be up tomorrow.
all this needs to go im in no hurry and i think im asking a fair price, considering the wastegate alone is worth over a grand.
all parts are located in the ACT and are for pickup only or delivery to local areas for fuel cost can be arranged!
Thanks for looking.
https://www.sau.com.au/forums/topic/145503-fs-act-vl-turbo-conversion/
