Hey guys, I would love to get my hands on a set of talking BOONY and BEEFY dolls but I hate VB.
Anyone got any codes they aren't using? or if you could send the ones you've already used that could be good to. Just Msg me. Thanks.
https://www.sau.com.au/forums/topic/145510-boony-codes/
Since there isn't a new user thingy, I'll just post in the top topic with an old fashioned 'hey all' thing.
I just bought an R33 last friday and 'IanB' told me about this place, so yeah, hello all. Look forward to telling you all sick jokes and getting drunk and posting random shit in the spam thread (in the whore town thread, Im not going to spam the topics) .... because I'm like that. Hell I'm half cut now. w00t in a handbasket, the SUA QLD application will be in the mail tomorrow and I'll be BPAY-ing the nessessary tonight.
Sorry for the deviation in the topic here, just didnt want to be one of those tossers who make a new thread for themselves to say 'hi'
-Ivonin
Edited by Ivonin
https://www.sau.com.au/forums/topic/145510-boony-codes/#findComment-2725324
I'm sorry, but if you can't suck back a few VB's then you don't deserve a talking boonie. Hell if 4X gold had a promotion I wanted I'd drink that camels piss. I'm sure there is some sort of unwritten law or curse that would fall upon you if you gained an alcoholic promotional gift by deception. But after all that, here's a code I'm not going to use. 153983135
nah just kidding. I made that one up. :laugh: Sorry, just messing around.
https://www.sau.com.au/forums/topic/145510-boony-codes/#findComment-2725801
  • 1 month later...
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
