lol just a play on wrods. The main reason I made it was to save people always having to press the thing off. It's just plain annoying, especillay when you forget. Maybe not as much for the low power 34's on here. But when your car doesn't require much effort to get "slip" flash up all the time it's handy for it to default to "TCS-Off"
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
