Vl Turbo 5spd 410 Rwhp Syd $11,000ono
1987 model vl turbo,original berlina factory turbo 5speed,many mods,very neat clean car,white over silver, sydney based,car made 305rwkw at 20.5psi,and is currently set betwwen 10psi and 18 psi and 18psi was making 289rwkw,the 305 was just a quick squirt to go over 300kws as the injectors were maxing out,so car left at 18psi,ran 12.9 at wsid on 10psi and ran 12.2 on 16psi and ran as quick as 116mph,so car will go mid to high 11s with someone who can launch a manual car properly,pm me for more details or ring me on 0418672588,genuine reason for sale,$11,000 ono
http://www.cacklingpipesphotography.com/06...t291106_138.jpg
above is a link to a photo of my car at wsid the other night,look for xkj-___ number plate
Edited by vlaldo
Have u got some pics?Not interested in swapping for a R32 skyline?
give us your email and can get some photos off to you,not really interested in a swap,would like to keep the car ,but was retrenched from work bout 3 weeks ago,and with a 2 yr old and a 7 week old boy,the family comes before the car,clean and neat vl,could be mistaken for a stock one except for lumpy idle.
possibly email some pics to [email protected]?
Cheers mate
[email protected] cheers
i thought i sent you some interior and engine shots,did you get em?list of mods its a 87 model factory turbo 5 speed berlina,white over silver calais look,skirts and rear and calais lower molds,it has 17'' gmh vx ss rims 235/45/17 tyres,very neat condition.interior is in top condition as well,electric mirrors remote central locking with 3 pt immobiliser,cruise control,electric areial,a/c ,p/steer,momo wheel,pioneer cd player with mp3 and 4 quality speakers.mx7 5 speed,rebuilt diff with new lsd centre,4.11 diff gears,kings springs ,bigger sway bars ,new back shocks and poly bushs,2mth old exedy extra heavy duty clutch,set up by western clutchs.new intank pump,3litre surge tank,bosch 044 800hp external fuel pump,gtr 440cc injectors,sard fuel reg,haltech e6x ecu,haltech electronic boost controller and 3bar map sensor,new wiring loom done when haltech went in.new jpc/crow stage 2 cam,performance heavy duty double valve springs,romac adjustable cam gear,cometic 3 layer head gasket,avo stage 2 front mount intercooler,garrett gt35/40 internal gate turbo off xr6 turbo,.5 front 1.06 rear,new water and oil line braided and speedflow fittings,oil catch can,new fuse rail.thats about all i can think off for now,if your keen give me a call and i can give you a look,as it goes in the trading post this week,im from out penrith way and my no is 0418672588,inspection will not dissapoint
 Share
    • Wow its been a while since Ive signed in for sure.  Time gets away... Good question. So much was different between the two designs.  The RB315 was a test to see if I could do it.  Limitations were for the most part due to local machining capability.  Tolerances were an issue.  The 3.15 used a single OD dry sleeve, and was almost the same as a kakimoto spacer plate engine, except I used a plate design similar to the OS Giken plate.  I did not make the top flanges thick enough either.  I can't be sure if it was machining tolerances, or thermal distortion of the sleeves, but the engine did produce quite a bit of blow by.  The modified 87mm RB30 crank was also an issue, and was no where near as nicely balanced as the forged 90mm crank in the 3.4. The 34 was a next level build.  The sleeves were stepped for max thickness, and were a semi-wet design breaking though into coolant completely in the block.  Minimum thickness was 3.75mm and max was 5mm with the 90mm bore, and the new spacer plate also fully supported the tops of the sleeves closed deck style.  This combined with far superior CNC machining, and a cylinder hone finish that the machinist does on 3000hp pro stock cars resulted in no noticeable blow by at all.   In the end the 3.15 was removed to swap in the 3.4.  I discovered the modified RB30 crank had partially sheared the woodruff key on the balancer.  That was all that was wrong with it, but it did make the engine a paperweight at that stage. $1100 to make another crank for an engine with blow by issues was not worth it, considering I'd started playing with all Nitto forged internals instead. I hope you found this interesting.   Cheers, Ian
    • All their parts, when order directly off them are made to order. So you're able to customise fitment of things or delete things. E.g. I asked for no throttle cable bracket, no IACV port, etc. on my plenum. In hindsight, I should have asked for an IAT port/fitting welded on, hindsight no. Should have bought a M2 or 3 lol.
    • 25de in c33 a31 is different to r32/r33 s1 which is different to r33 s2 & r34 so you can vaguely do whatever man.
    • That's the pink sticker type, you haven't said what car so no idea if it's correct, 25de or det is the same in the same model.
