Has anyone thought about a TB48 (with turbo) conversion to thier RB powered car?
I believe someone over east was looking to build an altered drag car with one.
Makes for an interesting concept if it will fit in the engine bay considering reduced effort in making very large amounts of power, perhaps even 1,500+ hp with a 5.15L stroker like this kit;
http://www.briancrower.com/makes/nissan/tb48.shtml
https://www.sau.com.au/forums/topic/145560-tb48de-turbo-conversion-anyone/
cappa do a supercharger kit for them, but there is no way in the world it would fit in a sedan
turboing them in the patrol wouild be a great option but costly....
we curently service some basicly moded 1ns (extractors, zorst,chiptorque pigyback, aircleaner) and they go great compaired to a std 1....
turboing 1 would be great...
the guy at the 4wd joint next to work has a race patrol its fited with a 4.2 petrol with a turbo and its suposed to fly... ill try to get a power reading or a dyno sheat. the extra capasity would be great.
some actual engine dimensions would be good to quantify the 'huge' part, having seen a few conversions in patrols the Tb42/48's not as big as a chev/LS1 or holden V8. They are obviously bigger than an RB engine but, they sure aren't 'huge' in the passenger car engine world.
We know someone has plonked an LS1 into an R33 so it would be interesting to find a bit more 'real' info out.
6boost was the guy looking at building the drag car with one from memory.
I agree even stroked these engines arnt anything massive, but with the extra capacity would come alot more torque and potential to make huge power. But whether it would be worth the cost of the conversion and the messing around would be another thing.
I think it is certainly a serious setup proposition, the kit to build a TB48 stroker is alot cheaper for a 1200+ hp setup than anything offered in the RB space. Where money and hassle are par for the course.
Whether there is an easy way to plonk one in the engine bay is another case. If it is relatively straight forward the potential is hard to overlook.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
