Has anyone thought about a TB48 (with turbo) conversion to thier RB powered car?
I believe someone over east was looking to build an altered drag car with one.
Makes for an interesting concept if it will fit in the engine bay considering reduced effort in making very large amounts of power, perhaps even 1,500+ hp with a 5.15L stroker like this kit;
http://www.briancrower.com/makes/nissan/tb48.shtml
https://www.sau.com.au/forums/topic/145560-tb48de-turbo-conversion-anyone/
cappa do a supercharger kit for them, but there is no way in the world it would fit in a sedan
turboing them in the patrol wouild be a great option but costly....
we curently service some basicly moded 1ns (extractors, zorst,chiptorque pigyback, aircleaner) and they go great compaired to a std 1....
turboing 1 would be great...
the guy at the 4wd joint next to work has a race patrol its fited with a 4.2 petrol with a turbo and its suposed to fly... ill try to get a power reading or a dyno sheat. the extra capasity would be great.
some actual engine dimensions would be good to quantify the 'huge' part, having seen a few conversions in patrols the Tb42/48's not as big as a chev/LS1 or holden V8. They are obviously bigger than an RB engine but, they sure aren't 'huge' in the passenger car engine world.
We know someone has plonked an LS1 into an R33 so it would be interesting to find a bit more 'real' info out.
6boost was the guy looking at building the drag car with one from memory.
I agree even stroked these engines arnt anything massive, but with the extra capacity would come alot more torque and potential to make huge power. But whether it would be worth the cost of the conversion and the messing around would be another thing.
I think it is certainly a serious setup proposition, the kit to build a TB48 stroker is alot cheaper for a 1200+ hp setup than anything offered in the RB space. Where money and hassle are par for the course.
Whether there is an easy way to plonk one in the engine bay is another case. If it is relatively straight forward the potential is hard to overlook.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
