hi all.
i need to know the diferance in the interchangability between 32/33/34gtr suspension. i know the tops are diferant. but what about the bottom. in paticular the rears.
like. is there a length diferance? or is is neglegable.
any info would be much apreciated. as im about to buy some 33/34 aftermarket suspension.
cheeres :)
https://www.sau.com.au/forums/topic/145612-r323334gtr/
there is definately a length difference between 34 and 32 shocks. whether or not it will be a problem I dont know for sure. But I have a feeling it may be. :D
only one real way to find out big boy :)
https://www.sau.com.au/forums/topic/145612-r323334gtr/#findComment-2722190
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
    • Hard line it, you will be thankful later on, if you car had hicas, use that as your return.
