OK People ... Doesn't appear to be a rip as it's actually on Top Secret's site!!!! nor a photo-chop!!! http://www.topsecretjpn.com
Do some homework before slandering!!! :(
Engine is more that likely the 3.5L V6.
Nissan are apparently pitching more to the American market :(
The GTR is said to be retaining the stovetops ;) (source - speed magazine) and will look more like the Concept car...
I haven't seen the veilside 35 yet, but I'll check it out ;)
46n2 :alien:
i think the 350Z looks better with the associated kits to be honest than that V35 topsecret think. There was a site that had all the kits available/coming for 350Z including veilside, etc - some were quite impressive.
yeah, V35 is going more "luxury sport" with the associated pricetag and lack of turbo :(
i can't believe they dropped the stove tops for the V35 - to me i don't really consider it a "skyline" without the turbo option and stovetops..
wonder whether they will do a GT-T/gts-t version after the GT-R is announced?
Guest cosmo
Originally posted by StraightSix
Considering that the n/a engine it has already has just as much power as the RB25DET, I somehow doubt it.
J
Actually it has more. The G35 Coupe has 280 hp and the 4 door has 260 hp. They are basically detuned 350Z's with a back seat and a little softer suspension
I don't see Skyline badges on it anywhere. :)
Engine type 3.5 liter V6
Drive type Rear-wheel drive
Horsepower 280 @ 6,200 RPM
Torque 270 lb-ft @ 4,800 RPM
Suspension Front: Sport-tuned independent, forged-aluminum multi-link with coil springs over ripple-control shock absorbers, 2-way bushings, stabilizer bar.
Rear: Sport-tuned independent, forged-aluminum multi-link with coil springs, outboard ripple-control shock absorbers, 2-way bushings, stabilizer bar.
Valvetrain DOHC, 4 valves per cylinder with microfinished camshafts. Continuously Variable Valve Timing Control System (CVTCS) for intake valves.
Intake system High-flow tuned induction system with micropolished tract and ports.
Compression ratio 10.3:1
Fuel delivery Sequential multi-point fuel injection
Recommended fuel Premium unleaded
Brake rotor dimensions
Standard 11.65" x 0.94" front rotors/11.50" x 0.63" rear rotors
Brembo® 12.76" x 1.18" front rotors/13.07" x 0.87" rear rotors
ABS type Computer-controlled 4-channel, 4-sensor with Electronic Brake force Distribution
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
