OK People ... Doesn't appear to be a rip as it's actually on Top Secret's site!!!! nor a photo-chop!!! http://www.topsecretjpn.com
Do some homework before slandering!!! :(
Engine is more that likely the 3.5L V6.
Nissan are apparently pitching more to the American market :(
The GTR is said to be retaining the stovetops ;) (source - speed magazine) and will look more like the Concept car...
I haven't seen the veilside 35 yet, but I'll check it out ;)
46n2 :alien:
i think the 350Z looks better with the associated kits to be honest than that V35 topsecret think. There was a site that had all the kits available/coming for 350Z including veilside, etc - some were quite impressive.
yeah, V35 is going more "luxury sport" with the associated pricetag and lack of turbo :(
i can't believe they dropped the stove tops for the V35 - to me i don't really consider it a "skyline" without the turbo option and stovetops..
wonder whether they will do a GT-T/gts-t version after the GT-R is announced?
Guest cosmo
Originally posted by StraightSix
Considering that the n/a engine it has already has just as much power as the RB25DET, I somehow doubt it.
J
Actually it has more. The G35 Coupe has 280 hp and the 4 door has 260 hp. They are basically detuned 350Z's with a back seat and a little softer suspension
I don't see Skyline badges on it anywhere. :)
Engine type 3.5 liter V6
Drive type Rear-wheel drive
Horsepower 280 @ 6,200 RPM
Torque 270 lb-ft @ 4,800 RPM
Suspension Front: Sport-tuned independent, forged-aluminum multi-link with coil springs over ripple-control shock absorbers, 2-way bushings, stabilizer bar.
Rear: Sport-tuned independent, forged-aluminum multi-link with coil springs, outboard ripple-control shock absorbers, 2-way bushings, stabilizer bar.
Valvetrain DOHC, 4 valves per cylinder with microfinished camshafts. Continuously Variable Valve Timing Control System (CVTCS) for intake valves.
Intake system High-flow tuned induction system with micropolished tract and ports.
Compression ratio 10.3:1
Fuel delivery Sequential multi-point fuel injection
Recommended fuel Premium unleaded
Brake rotor dimensions
Standard 11.65" x 0.94" front rotors/11.50" x 0.63" rear rotors
Brembo® 12.76" x 1.18" front rotors/13.07" x 0.87" rear rotors
ABS type Computer-controlled 4-channel, 4-sensor with Electronic Brake force Distribution
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
