Enormous turbo, or two I.e. 2 x ~GT35s
Complete engine build; decent forged pistons/rods/HG etc. Full headjob port, valves etc, high lift camshafts springs etc.
Multiple fuel pumps/surge feed system, with suitable fuel rail(s)
Aftermarket gearbox/gearset, diffs, etc.
Race fuel might help.
Fuel pressure. 880's are 880hp before you begin to even bump the rail
He doesn't list a pressure reg on the list of mods, i would agree that it must have one, but he must like living on the edge, duty cycle must be close to 100% even with heaps of pressure, 614rwkw i figure to be about 1050 fwhp
Dont forget that drive train losses are proportional to RPM and effected by gearing, it is not proportional to power.
Losses should be in the 50kw range? If so, equates to ~890hp at the flywheel
So your saying that there is over a 270hp drivetrain loss basically?
You can only really guess this sort of thing but 60kw is usually accepted for drive train losses and id supect more than this for this car. With the high RPM's and high power output a lot more heat is generated and trasfered. So my gestermation is say a consertitive 80kw loss instead of 60kw.
614 + 80 = 694kw = 930hp
So taking guesstimation into account 900 to 1000hp.
cheers
drivetrain loss is usally 20% in awd i am build up a track car in the next 4 yr i want 750hp at the wheel 4 wheel drive. i am crazy. i want to take it to japan as well. and run it in the 1/4 mile strip in america. a world traving car. thanks for ya'lls help i wonder how you hook up 3 fuel pumps?
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
