ahhh thats not a bad idea mate, thanks, when you say you drove a your 33 turbo does that mean you where driving it illegally? if thats the case, where you getting pulled over left right and center or what was the go there? how did you avoid going to court? (this is not me kicking your suggestion in the teeth stuartlaw_78, merely just curious :) )
I have never been pulled over in my 33. Got pulled over more in my celica than 33. I think in terms of getting pulled over etc has a lot to do with where you live and therefore where you are driving around. I think at the time i didn't really care all that much about the legalities of the car, many of the cops around my area wouldn't have a clue, but as i said it was only for 6 mnths. big chrome wheels, stickers, burnouts etc will prob get you pulled over... :dry:
I have never been pulled over in my 33. Got pulled over more in my celica than 33. I think in terms of getting pulled over etc has a lot to do with where you live and therefore where you are driving around. I think at the time i didn't really care all that much about the legalities of the car, many of the cops around my area wouldn't have a clue, but as i said it was only for 6 mnths. big chrome wheels, stickers, burnouts etc will prob get you pulled over... :thumbsup:
ahh what you say is true, but then if i had those things on any car i'm sure i'd get pulled over...i guess ill test drive both and just see what happens, you said you had 3rd party insurance, but i read insurance companies won't pay out because it's an illegal car anyway?
i guess you where lucky enough not to get into any accidents...
ahh the decisions are endless and so hard...i live in a pretty low risk area, eastern sub's of melb but hrmmm...
I would say go for the NA R33. It has a bit of guts and obviously the look you're after. Just remember, the difference in insurance cost at your age between the turbo and non turbo, will pay for an RB25DET in a few years. So, get the NA and the do an engine swap later. That's what I'm doing :P
I'm 22, so a bit older, but insurance is still a big thing.
This gives you time to look after the little things such as stereo and interior trim etc. You don't need to touch the engine, cause you gonna swap it later anyway.
I don't want to get your hopes up too much. Its nothing like the turbo, obviously, but it does go compare to many other non turbo cars. If its got enough power to get sideways on you (which it does), without putting your foot to the floor, I'd say its a good starting point for a responsible P driver. :D
Go for a test drive in one and see what you think. After test driving mine, I had a grin from ear to ear, but every person has to feel for themselves.
Good luck with the search.
hey im 21 and just bought a 95 r33 gtst have about 3 yrs driving experiance now though just thought u might like a bit of an idea on insurance, ive never had a fine or anything, no accidents and im paying 1700 a yr on insurance with young and cool. they are a good company by the looks of it and let you pay by the mth however it is a cpl of hundred a yr more. my first car was actually turbo, but was ff, it was a old n12 et turbo pulsar. i paid 13000 for my gtst with 108000kms on the clock, bought it the day it came back from compliance, so you should be able to get a top na r33 for that budget.
hey man, i own a r33 non-turbz on my Ps too, its not blazingly quick but it still has abit of guts to it. With the insurance, i pay $550 for third party fire n theft.. i think a turbo r33 third party fire n theft is around the same price so the insurance doesnt really change a whole lot. I think they consider any skyline a greater risk car. But with driving a non-turbo r33 i have peace of mind that i will get paid out if i crash :laugh:
theyre good cars, and i recommend one for a first car! i have nearly spun out in it, in the wet and if it was turbo i know it would have been a totally different story, with me wrapped around a pole probably. so just have a think of it all before you make up ur mind
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
