hey guys, i was thinkin of gettn a fmic, but i dont wana lose power, cause i dont boost my car often.
i chuk on the bleed valve on weekends sometimes, set at 12.5psi.
ive got a remapped ecu
turbo bak exhaust
and a pod filter.
my boost guage is reading 10psi without the bleed valve on (naturally the boost has increasd cause of my mods) if i was to buy a fmic, would i lose power if dont boost it to 12-13psi? i dont like to keep it boosted cause i dont wanna get done by the cops...
is ther any point in gettn a front mount if im not gona be runnin 12-13psi?
cheers...
Edited by 32line
you wont loose power exactly but there will be more throttle lag as each time you open the throttle, you have to pressurize all the extra pipe work and larger core over the stock unit.
yep, the pick of the bunch for your application would be standard R34 intercooler, or ARC sidemount (similar to the HKS sidemount Sewid has). Cheaper than FMIC, easy to install and legal. and good performers.
As said...a larger fmic won't cause a loss of power...a slight bit more throttle lag as mentioned but hardly noticeable...you'll still get small power gain as the air is cooler and the restriction from the stock smic is gone...in my case...even a shitty hybrid style cooler gave a noticeable gain...
wat bout a stock 32gtr cooler?
r32 gtr cooler is a front mount so ... if you're going down the front mount path an r32 gtr cooler is a more expensive option and there aren't that many great examples floating around for sale.
Just to let you know that the R34 gtt cooler is not a straiaght fit to r32 gtst. You will have to either modify the endtank on the GTT cooler so the outlet faces forwards OR modify the R32 pipework so it lines up.
I'm contemplating which to do myself at the moment. Not sure.
Modifying endtank - can get a welder to do it for about $50, get to keep my stock piping (so i can refit a stock cooler if i ever want easily). Can be done with my car still going (big plus when i have to get to the welder and back) But the end tank is designed to flow best to the current outlet position, so modifying the endtank could decrease flow capability slightly.
Modifying piping - unsure what exactly needs to be done. May involve cutting the car body. Never be able to refit stock cooler. If the stock piping cant be modified to fit directly, I'll be stuck. Upside - endtank doesnt have to be modified, dont have to go to welder.
So still not sure what to do...
Apparently the gtt cooler should be able to handle 200-220rwkw. More than I'll ever have, and I have a water spray kit ready to go on at the same time. I'm looking to go to a sliding performance RB25 highflow eventually but thats it, so the gtt cooler should be perfect.
Rhett
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
