That was my first cruise and was awesome to see so many people turn up, crazy seeing so many skylines nose to tail. I had to bail after snags for the trip back to Burleigh Heads but drove back with a smile on me dial, was a great day out.
I have some very ameture video footage of the cruise I will edit and upload to youtube.com over the next few days. :P
https://www.sau.com.au/forums/topic/145735-thanks-for-the-charity-cruise-guys/
Big thanks to everyone who put the long hours into planning this event and all the people that attended.
Was a great day out, anyone count up how many Skylines were actually there?
Can't wait too see some photos and videos of the SCC. Hope we raised alot of money for the Charity as well!
Once again, thanks guys!
had a great time. was alos amazed with the amount of people that knew who I was (since I have never met most of them.)
only downer I saw were the guys in the R31's that after being thamked for their support and asked not to behave as twits proceeded to do so. my suggestion would be not to let these guys in again unless a stern warning was given. it was th R31 skyline club that I am talking about here.
congrats to Jason Gherke for arriving 20 min before the prize draw and nabbing the radio and speakers I donated (lucky bugger!!)
I have a few pics as well that I'll get up once I get tim to shrink them.
props to the events team for a well run day.
Thank you SAU and the Events Team for such a great day,
also thank you to the helpers today without you guys it wouldn't be so perfect once again thank you.
only downer I saw were the guys in the R31's that after being thanked for their support and asked not to behave as twits proceeded to do so. my suggestion would be not to let these guys in again unless a stern warning was given. it was th R31 skyline club that I am talking about here.
^^I know skiz and burnout are fun, I do it sometimes aswell BUT there is a time and place to do so, NOT ON A FU(KING 2 LANE ROAD NOR ON A CHARITY CRUISE.
Michael A.K.A MRR34
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
