R34 NEO's have different throttle(traction control) different cam angle sensor, solid lifters, fully variable inlet cam/valve timing, smaller combustion chambers, slightly different exhaust manifold, slightly different turbo with bigger exhaust housing, flat top pistons, top feed injectors, bigger intercooler, and different coil mountings, i think thats it?
Different wiring. I did an engine conversion on my R33, and now it has an RB25DET NEO in.
http://www.skylinesaustralia.com/forums/in...amp;pid=2702999
If you want details, you probably can call Mercury Motorsport at 1300 558 650 to find out more; they did my conversion just a few weeks back.
Valve lash by bucket + shim arrangement on Neo, similar to RB26 setup.
More like a vg30, as a neo has the shim ontop of the bucket, wheras the rb26 is underneath(and a real pain)And one of the valves are bigger than an rb25(cant remember if its in or ex)
