Just purchased my GT3071R
56 trim, 71mm compressor wheel
4inch compressor cover
T3 flanged with 0.71 exhaust a/r,
which mates up with the stock dump-pipe.
Cost me $1900 from Rotomaster in Melbourne
Would of cost me a further $100 for a GT30 style 0.63 ex-housing,
but would of cost a further $300 for a custom dump pipe.
Oil and water lines were custom made by HIS and cost me $330- all braided except oil drain pipe.
Some bango fitting from the stock unit were chopped and re-used.
BTW - Turbo needs a 10mm spacer between turbo and manifold,
as comp cover is quite large.
Stay tuned for further updates...(more pics/ dyno graph/etc.) :)
Edited by Nabil
https://www.sau.com.au/forums/topic/145752-project-gt3071r-in-progress/
  • Replies 58
The compressor cover was hitting the manifold,
so I had to use a 10mm spacer and remove the four manifold bolts.
I replaced them with approx. 10mm longer ones
Below is a picture of the four bolts that had to be removed
and replaced with longer ones.
(4 bolts and nuts from Metric Man cost me $6)
The yellow rectangle highlights the section of the manifold
that comes into contact with the compressor cover.
Edited by Nabil
Latter on i realised that it was not sitting flush with the manifold.
The heat shield had to be removed & the bottom right bolt had
to be threaded in 5mm deeper as i could not put the nut on it.
This is a picture of the set-up when I placed it on this morning at 4:30am
(Me and my mate were burning the midnight oil into the early hours of the day. :) )
the arrow is pointing to the bolt that had to be threaded deeper.
Will use a power fc
ATM: Mods are:
Full 3inch exhaust
Apex FMIC (its quite small)
HKS GEN 3 EBC
BOSCH pump
HKS mushroom filter
It made 211.2rwkw on 12psi with a SAF-C
Cannot wait till this one starts spoolin' :)
That looks like a big comp cover - no wonder you needed the spacer.
What is the origin of the turbine housing? 0.71 A/R with T3 flange seems a bit of an unknown.
Will be very interested to see how it goes for you. One of these should offer response and good power.
Any chance of a clear shot of the ID plate with numbers?
why the standard dump pipe? that will be hella restrictive!!!!!!
none the less top stuff :)
Ill be watching this thread closely as I am going an externally gated 30R on my 20
-Jez
Edited by Wheezy
Just curious if this on a RB20 or 25.. I have purchased a GT30 with that .64 option above(have to look into the exact specs of it when i get it). Would be keen to compare if yours is on RB20, though mine wont be tuned till mid Janurary.
Are you planning on using camshafts at all cause Id also be curious to see what you choose. Cams are a unknown area to me and any advice I can get would be a bonus lol...
cheers Dan.
Edited by Smooth
cheers Dan.
Its going on a RB25
Will probably put a set of 550cc injectors
Still debating on wether or not i will put camshafts. :)
Will post a pic latter on today.
The oil line comes out lower down and at the side of the block for mine ['98 rb25], did this change? Was it different for earlier models?
The photo shows the oil line coming from the back of the block?
Just curious........it could just be in the rotation of the housing etc
Pretty sure its the rotation.
On the photo the compressor and exhaust covers were not yet adjusted.
Im installing a Gt3071R as well. Certainly not a bolt on operation, just about finished though, should have it firing tonight
I know its a headache.
The next person that says to me the words 'bolt on' will lose his teeth.
Go to go know...back to thw garage. :dry:
Damn - some cool things going on with RB25s at the moment. I will watch with great interest at how the GT3071Rs go - I got >< close to going one, but decided a GT3076R in the end.
The RB25 dyno thread will be interesting watching soon!
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
