Guest MRE Posted April 24, 2003 Share Posted April 24, 2003 Uniden UBC120XLT Handheld scanner featuring Twin Turbo Scan & Search. Channel lock-out and unique data skip facility are also included. Complete with NiCad battery and charger, belt clip and rubber duck antenna. Also have car charger. FEATURES - Memories: 100 - You can program each of these memory channels to store one frequency - 11 Bands, 10 Banks - Includes 11 bands with Aircraft and service search. Ten banks of ten channels are useful for grouping similar frequencies and selectivity scanning these groups. - Pre-Programmed service search - This feature allows you to toggle through police, fire, emergency, aircraft and marine frequencies. - Twin Turbo, Search and Scan - TurboScan allows you to scan up to 100 channels per second and TurboSearch lets you select either 100 or 300 steps per second when searching frequencies - Data Skip - This feature allows the scanner to skip over unwanted data transmissions and substantially reduce birdies - Manual Channel Access - Go directly to any channel without stepping through other channels - 10 Priority Channels - Keep track of activity on your most important channels while monitoring other transmissions - Memory Backup - Retains memories etc for more than 3 days without batteries - Programmable Search - Allows you to set up the upper and lower limits of a specific frequency range for easier searching - Channel Lockout - You can skip over channels you don't currently want to hear - Rechargeable Ni-Cd battery pack - A rechargeable nickel-cadmium battery pack will supply up to 12 hours of use in the close squelch position (normal specification) SPECIFICATIONS - Frequency range: 66 - 88, 108 - 174, 406 - 512, - Modes: NFM, AM (auto-select) - Memories: 100 (10 banks) - Scan Delay: 2 seconds - Antenna Connector: BNC - Modulation Frequency: 1KHz - Power supply: 13.8 VDC internal cell pack - Weight: 358g (inc antenna) - Size: 63.5W x 152.4H x 44D mm Conditions of sale. This is open to highest bidder. Brisbane Only COD The highest offer will be PMed with my PH number. Can deliver Brisbane only. I reserve the right to withdraw item for whatever reason. Link to comment https://www.sau.com.au/forums/topic/14578-hand-held-scanner-brisbane-only/ Share on other sites More sharing options...
WHITE R32 Posted April 24, 2003 Share Posted April 24, 2003 these are great scanners...... i know how much they are new ..... i used to have one i regretted selling it... MRE what sorta nick is it in and can we have a rough starting figure please????? Link to comment https://www.sau.com.au/forums/topic/14578-hand-held-scanner-brisbane-only/#findComment-295986 Share on other sites More sharing options...
