Obviuosly manual.
Anything rwd with decent power. I'm assuming that you don't have a skyline?
No your mum's auto vn commo will not drift well.
Basically, any turbo skyline/silvia/rx7 etc etc will drift ok
na cars can be drifted more and require more skill.
General mods required:
mech diff (a must, once you move from the stock viscous to a mech, you'll notice the diff. When the stock one single wheels, you'll lose control)
suspensions
seat and harness are nice, so you aren't always triyng to brace yourself off the door etc.
stock power is enough to learn on, but air filter, exhaust, highflow cat, fmic won't hurt.
oil cooler depending on how hard you drift (on a 31 degree day, my r33 was starting to get hot, but I drive hard)
camber, castor, swaybars etc.
https://www.sau.com.au/forums/topic/145796-drifting/#findComment-2723431
RX7's ARE NOT GOOD FOR STARTING TO DRIFT IN.
The only cars you should be looking at are S13 Silvias or maybe DR30/31 Skylines. Someone may be able too drop futher info on those skylines for you compared too the S13.
https://www.sau.com.au/forums/topic/145796-drifting/#findComment-2723451
anyone watch serious performance 7 i htink.. when the drifter got into the stock auto VT and piled in 4 mates too..... i think it was adam newton if im not mistaken, he did alright, and would have done 100 times better if he had just an LSD
https://www.sau.com.au/forums/topic/145796-drifting/#findComment-2723475
thanks man naa not yet but yer im lookin for a skyline though im from wa as well where r the drift practice days
check out
www.driftwa.com
or
http://westdrift.com/
you will get all the information you need on where to drift in perth and how much it will cost you :)
AndyMac: it doesnt matter what car you have, althou you think an rx7 will be hard to learn in, other people may fine it quick easy;
https://www.sau.com.au/forums/topic/145796-drifting/#findComment-2723479
Anything can be drifted. My last rental vt commo was pretty fun even though it was auto.
like It was said above, it's how well it drifts, and how easy it is to learn.
What's wrong with rx7s?
My friends fd is very easy to drift. Stock, they're pretty neutral in terms of over/understeer.
https://www.sau.com.au/forums/topic/145796-drifting/#findComment-2723484
' date='3 Dec 2006, 08:22 PM' post='2723479']
check out
www.driftwa.com
or
thanks man i wil have a look at them
https://www.sau.com.au/forums/topic/145796-drifting/#findComment-2723493
manual r31 skyline
pull out diff centre, weld it up
has n/a rb30 so enough torque to go for gold. if you get desperate for more power just whack on vl turbo setup. then it'll tyre fry no worries
and some average to half decent shocks money permitting
can even chuck in s13 front arms to go down the s13 coilover route
live axle so its fun to drift with. no hicas or irs dramas
fatz from this forum can prove they are good to go for a cheap weekend fun car ---->
cheers, MARK
https://www.sau.com.au/forums/topic/145796-drifting/#findComment-2723510
Get an NA car weild the diff....stiffen it to buggery...have a manual and a handbrake that works really well. A corolla with a 4age is fun......a skyline is fun but tends to steer out of a drift cause of the HICAS (remove it and its good). Learning in an underpowered car can teach you to take the right line a speed, can get your confidence up, with a turbo car you can have other problems.
https://www.sau.com.au/forums/topic/145796-drifting/#findComment-2723511
lol look at all that body roll, im guessin its still got stock suspension..... any more info on that car?
nice to see the vid stopped right before he speared off the track in that first bit of the clip
https://www.sau.com.au/forums/topic/145796-drifting/#findComment-2723577
That vid was taken when it was a stock standard R31 Silo, prob with a welded diff.....
this is what they did to it :dry:
https://www.sau.com.au/forums/topic/145796-drifting/#findComment-2724100
  • 3 weeks later...
Just wait till it rains and take your shit box auto commy out and learn that way. Thats what i did i got a feel for drift first then started to progress from there. Then when you progress more then mods start comming from what you know you and your car needs to feel right.
https://www.sau.com.au/forums/topic/145796-drifting/#findComment-2784876
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
