Hi
My R34 GTR had an engine change after a conrod bearing damage, the engine fitted was a standard R34 GTR vspec engine with approximately the same mileage of the car.
The GTR is fitted with some GT-SS turbos, nismo 600cc injectors, nismo fuel pump, nismo fuel regulator, hks exhaust and decat pipe, apexi power fc with commander and boost control kit.
With the new engine fitted, the gtr was tested and driven for one week,
the engine is running fine, oil pressure is good, they just had to adjust the idle that was a little too high, adjust the power fc map, and all the knock, wideband and other measures are ok.
Now after driving the car for one day, after one hour driving on the highway,
it started to do some short misfires, similar to a boost fuel cut, sometimes around 4000rpm and not under full load.
When doing this the engine check light was sometimes coming on for less than one second, without flashing at all.
Anyone has some suggestions on what it could be?
It was also raining, I don't know if this could have caused some water to get in the AFM's with the standard airbox, or if it could be something else, injectors, spark plugs, coil packs or just something wrong in the power fc settings but it shouldn't have driven perfectly for some time.
https://www.sau.com.au/forums/topic/145811-r34-gtr-misfire/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
