i kno power fc are cheaper i owned 1 for a bit, but i want something a bit different like the haltech and where im getting my car done they specoalise is haltechs and will do a goo deal for it
fair call mate if ya tuner will do a deal why not aye good luck with it all aye
i beam is better for torsonal loads ie.. hitting boost. h beams can be made lighter.
it really depends on what your aiming for. then you got the whole wich brand argument lol.
from the look of it youd be safe to use some cheap china made h or i beams like eagle, scat and some of the sub 1000 a set i beams.
Sts rods may be good. But by the time you crack test them , shot peen them, resize them and get good rod bolts for them are they any cheaper then the entry level rods you can get? Even Argo are cheaper these days as their pricing seems to have responded to the cheaper rods available on the market
Thats provided the Eagle etc rods are in fact better then what Nissan put in the motor.
By the time you 'prep' the std rods you may as well spend a tinny little more and grab a set of forged rods.
All engine builders (that I have spoke to when building mine up) said not to waste the $$ on 'prepping' rods when these days after markets can be picked up for so cheap.
It really is saving minimal cash.
Go for the aftermarket rods. A set of Eagles or similar will only cost you $300 or so more than modifying the standard rods and you have something brand new that hasn't done millions of cycles already and is a better design and stronger than the factory rod to start with. They may need slight machining to set the proper pin and bearing clearances but it will be minor, most aftermarket rods are supplied with the pin and big end bore finished to bottom tolerance to allow adjustments to suit the crank/bearings and piston pin. Don't be scared off by the rods being made in China, a lot of big name companies have either set up over there or have their parts made by chinese factories, it reduces the cost to make the same product.
  • 2 months later...
Just a quick point on testing standard rods.
Some one mentioned having them checked by x-ray rather than MPI (Magnetic Partical Inspection). To be honest its pointless having the x-ray done, its alot more expensive than MPI or DPI testing and unless correct technique is used it will not show up very very small cracks.
I would reconmend DPI (Dye Penatrive Inspection) Testing. This will show up any cracks or flaws and in my opinion is easier to do than MPI.
The rods are soaked in a dye for a few minutes and then cleaned off using water or a cleaner. A developer spray is then used, this will bring out any dye that remains in cracks or flaws and thus you can tell if the rods will be OK!
I was tempted to use standard rods but I think I will spend the extra cash and have new H Beam rods fitted, they are a good price now.
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
