-=Hand Held GPS=- Brisbane Only
Hand Held GPS Etrex Garmin
Product Features
Ultra-compact Size
500 Waypoints
Trip Computer
Backlit Screen
Track History
1 reversible route with up to 50 waypoints each
Product Description
Truly a small wonder, the eTrex® takes the best features of a 12 parallel channel GPS receiver and put them into a six ounce package that is only four inches high and two inches wide. The result is a unit that will literally fit in the palm of your hand.
Besides its small size, mariners and outdoorsmen will likely notice the sleek design of the eTrex. All buttons are located on either side of the unit, allowing for simple, one-handed operation that won't obstruct your view of the display. In fact, the eTrex features only five operator buttons for the ultimate in user-friendly design. Thanks to its bright yellow case, the eTrex will be hard to misplace and easy to find in any boat or backpack. The eTrex is completely waterproof so it can take an accidental splash or dunk in the water and still continue to perform.
Inside the eTrex, you will find the proven performance of a 12 parallel channel GPS receiver that will run for 18 hours on just two AA batteries. No need to worry about dense tree canopy with this unit, the eTrex will continue to maintain a tight satellite lock even while operating in forest-like conditions. The eTrex will store up to 500 user waypoints with graphic icons and boasts GARMIN's exclusive TracBack™ feature that will reverse your track log and help you navigate your way back home. In addition, the eTrex uses animated graphics that will help you identify your marked waypoints quickly and easily.
It also tells you speed, height above sea level plus more.
I have Data Cable (for PC) with Software and Car Charger
Conditions of sale.
This is open to highest bidder.
Brisbane Only
COD
The highest offer will be PMed with my PH number.
Can deliver Brisbane only.
I reserve the right to withdraw item for whatever reason
https://www.sau.com.au/forums/topic/14582-hand-held-gps-brisbane-only/
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
