hi, i need some help...
my boyfriend has a nissan skyline GTR R32...his turbo timer is broken and i am sick of sitting in the car waiting for the damn thing to cool down or whatever it is. Anyways, for his christmas present i want to buy him a new turbo timer, but i dont want to get him a crappy one....and since i know nothing about them , i thought someone on here might help me out....
Can anyone tell me what is a good one to suit his car?
:) thanks a lot in advance...!
https://www.sau.com.au/forums/topic/145820-a-good-turbo-timer/
theyre all generally the same...
I use a greddy full auto timer..
has extra features such as:
lap timer
Automatic time selector for the timer (the harder you drive it the longer it stays on)
You can preset up to 4 diff settings with each a max and a min timer value if your using the auto setting.
it also shows a digital reading of your speed
can measure 0 - 100 m times , 0 - 400 m times
and the feature i use the most haveing a big stereo is the batt. volume display in volts.
Its a cool unit and looks good.. i got mine off my mate he owns:
www.natetune.com
I paid about 130 bucks.. give him a holla :)
hope i helped...
Tell him that if he doesn't thrash the car the last 2 street corners b4 parking that he shouldn't have to wait for a turbo cool down. But if he insist on it, then as above, they r all more or less alike, some with a few more features than other like lap timers, A/F ratio(theoretical)... but all do the same job. Im running a Apexi pentype, cheap, slim, sleek n easy to hide(from the cops). HKS does a good one as well with 1/4 mile timer.
http://www.apexi-usa.com/product_electroni...8&pageNum=1
Check out the For Sale section, should be some decently priced ones there delivered.
thanks for the quick replies guys...and he is anal about cooling them down...as he is with everything about the damn car lol. His pride and joy...but it makes buying presents easy (maybe a bit expensive tho).
I didnt realise that they were all basically similar..
oh while i'm here i have one more question...he wants a tacho thing (is that what they are called) the one where the light flashes on when he needs to change gears or something. Anyways all he wants to install is the light without the gauge is that possible? Or can you not buy and install them separate from one another?
thanks again, you have been most helpful..!
Turbo Timers just trick the car into thinking the key is left in the ignition. They just count down then disconnect the circuit (take the key out). So yes they're all the same. $80 for a apexi pen timer is about usual.. I got a $30 second hand HKS one cos I like old school stuff. You shouldn't pay more than $100 for a new one in my opinion.
It is possible to get just the light. If you're looking at something you can buy off-the-shelf then you can get a kit thingy made by a company called Pivot which is pretty cool. They do sell JUST the light so don't get confused with the shift kit, you only want the shift light.
As someone said before if your bf cools the car down properly he won't need a turbo timer - usually they're only useful at the racetrack. Similarly he shouldn't need a shift light on the street... but then again the advice above is if you/he insists... gotta get some BLING BLING somewhere.
for the shift light I would suggest Pivot shift light. they make 3 types. one is a small type one, one is a large single light. and the other has 3 little lights that go off in stage. all very high quality, and easy to use and fit. They cost between $130 and $180 from memory.
for the turbo timer, maybe go for a pivot one too so it matches? or the Greddy one is good, as are the HKS ones. Personally I'd prefer the Greddy one.
I'm sure he will love both gifts. :dry:
check them out here:
http://pivotjp.com/product/shiftlamp/ssl-m-e.html
this is the pro, very cool:
and the "M" looks like this:
I'd reccomend either the "M" or the "Pro" as they are the least conspicuous of the 3 types. The X is pretty big.
you guys are gems. thank you very much for your help...i thinking probably the greddy one for the turbo timer...now i just have to decide...silver or black? hmmm maybe silver to match this stereo face thing.
and i will look into the pivot shift lights. :dry::) :)
where in Australia can i buy the "M" or the "Pro" shift light? anyone know?
I believe if you hit up the nissansilvia.com forums then the distributor is on there as bt-revolution. My tip to you is always bargain too :)
I'm a sucker for girls so here's a link - http://www.bt-revolution.com/Shift%20Light.htm
Oh and look out for the idiots and "experts" on that board, they have a higher ratio than SAU.. much higher.
did you hear that ?????
you guys are gems :)
:dry:
yep id go the silver looks good with the black dash unless you want to hide it... i got a silver 1... greddy is a good unit and not very $.
I believe if you hit up the nissansilvia.com forums then the distributor is on there as bt-revolution. My tip to you is always bargain too :yes:
Anyone know exactly how big the M n Pro light is, thinking bout getting one myself now. Damn this site... just makes me spend $$... lol. N i assume u can wire it to a 12V source with switch n fuse instead of using the cigarette lighter. Where do u guys place the light n black box with the +/- adjustments?
Sorry Rachelle, didnt mean to hijack ur thread. Get ur bf the pivot, he'll luv u for it... :wub:
Turbo Timer…..YUK
What do you want one of those for?
They are just an easy place for someone to steal your car.
Ooooo, I have to cool the turbo down after I thrash it.
Yeh, but what about the gearbox, didn’t you thrash it at the same time?
Oooooo, better buy a gearbox timer
What about the diff, didn’t you thrash it at the same time?
Oooooo, better buy a diff timer
If you were really driving fast enough to heat up the turbo then you probably used the brakes it to stop in the driveway.
Oooooo, better buy a brake timer
Surely it makes more sense to do a lap of the block to cool the whole lot down. Not just the turbo, idling in the driveway.
:wub: cheers :yes:
lap timer
www.natetune.com
hope i helped...
I also have the greddy turbo timer (Silver) got it from Autobarn from $130.
In reply to the others mentioning about easy to steal etc, I got a pro. to wire it into the imobiliser and alarm system so if the car is broken into whilst on turbo timer the car shuts down and its imobilized.
I heard that you don't need to cool the turbos down unless you drive like a hoon constantly but I drive on the hwy to get home 110km for like an hour so I do it just for safety lets the whole car take a breather rather then just shutting down. But each to their own.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
