I went to do the rear disk conversion on the C210 this weekend and came unstuck. The rear suspension arms from the rally car are somewhat bent, but my suspension arms dont have the 2 holes to mount the calipers.
So... will suspension arms from another model fit (r30 possibly according to another thread?) or will I need the arms or the whole rear suspension assembly, or do I need something fabricated?
The arms from the rally car were marked C210/C211 in paint pen, and looked identical except for the caliper mounting points.
The good news is that I got the R180 LSD to bolt straight up. Banzai!
Cheers.
https://www.sau.com.au/forums/topic/145835-drums-to-disk/
R30 hatch has a trailing arm with disk brakes (handbrake in the caliper), and, IIRC, the 280ZX had a similar setup.
R30 sedan has rear drums.
When I did the rear disk conversion on my old 180B SSS, we manufacture a bracket to suit the calipers. It used 3 of the bolt holes that hold the drum backing plate (so you don't need to remove the axle to fit or replace it).
So you have two options.
https://www.sau.com.au/forums/topic/145835-drums-to-disk/#findComment-2723955
you can't just whack a pair of r30 trailing arms in, they have different toe settings to the c210 and the resulting setup would be undrivable
the only way to do it would be to source a complete r30 rear suspension, or c210.
or make custom brackets.
https://www.sau.com.au/forums/topic/145835-drums-to-disk/#findComment-2724299
Most people fabricate a caliper mounting bracket and bolt it where the drum brake back plate was located - use all four holes .
A word of warning here - be very very sure of who does the fabrication/engineering in this area . I have seen a caliper bracket fail and take the caliper and its severed hydraulic line round inside the wheel till it all locked solid . Not nice to think of one rear wheel locked and little or no brakes left to save your life .
Cheers A .
https://www.sau.com.au/forums/topic/145835-drums-to-disk/#findComment-2725110
Sorry if this is a stupid question but... was there a C210 model that came with rear disks, and if so, will I only need the trailing arms or will it also have the same toe setting issues as the Mr30?
Thanks for the advice too!
https://www.sau.com.au/forums/topic/145835-drums-to-disk/#findComment-2725940
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
