  • Replies 167
i work just up the road from there as well, in beverly
i work @ berverly too im on toogood ave ?
not many people down my way it seems
Live at Richmond
my daughter goes to richmond primary school :P wonder if ill bump into 1 day when i pick her up
I work on alfred avenue at beverly, near the back enterance to email....See a few skylines around the area as i work arvo shift here!
ahk yeah im up there sometimes but never see your 33 in your avatar. I have a black R32 Gts-T Msport front bar, volks gt-p's, FMIC etc etc the usual. Give us a wave if you see me round.
No worries will do, and yeh my line has been off the rd for 6months getting a face lift its in a mates garage lol so close to finished its not funny, but my rex is at home i got it the other week and yep will give you a wave lol have to meet up when i get it back.
+ 1 for the southerners, i'm on the edge of happy valley. 30 secs i'm at the bottom of the windy section on chandlers hill road. Gateway to the southern & eastern hills i reckon, back hill roads all the way. :action-smiley-069:
prospect
prospect as well...thats 2 for prospect!
can drop by my place on the way to ingle farm, im at pooraka. whilst your there, you might as well drop by vange's place, prospect. :P
haha u stalking me duc?
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
