Hey guys and gurls..
i have a used 2.5" catback exhuast system came off my car.. i replaced it with 3".
but if your looking for a cheaper upgrade, then look no further.. it sounds nice and throaty.. yet not illegally loud.
cannon on the back.. has been sprayed black.. but its stainless cannon so it should come of with some elbow grease..
Looking for around $200.00 pickup.
Pics to come..
Express your intrest
Thanks
    • The way they do the test you would be very lucky to ever hit any cell that isn't aiming at 14.7 This was my result... Really not sure what's going on there!
    • I have a projecta one.  A proper trickle charger can be left attached 24x7, that's what the trickle bit is about.
    • With an electronic boost controller, there are settings available to limit overboost.
    • Ah ok, my tuner did adjust something on the percentage cycle on the boost controller, instead of running at 40% the tuner put it on 20% to compensate for the overboost, can't remember what it was. Not duty cycle don't think, and told me if it keeps overboosting, it's going to be something else. I think he mentioned the turbo actuator.
    • Which trickle charger does everyone use? I'm going on holidays in the future, and last time it was left for a couple weeks off twice per time, and don't want to keep doing it to damage my battery so looking to have something hooked up to the battery which connected to the car, as I need to keep my immobiliser system on. If the battery goes flat it will mess up my security system (already happened once) I was looking at the following, so can have someone turn it on every couple of days and run it overnight then turn it off)   https://www.supercheapauto.com.au/p/noco-noco-genius-5-battery-charger-6v-12v-5-amp/648987.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=1   https://www.supercheapauto.com.au/p/century-century-cc1206-xli-12v-1-3-6a-9-stage-battery-charger/693006.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=30   though these don't say anything about trickle charging, don't want it to overcharge the battery.
