Hey guys,
Changed my oil on the weekend and when i was pouring the used oil back into a container, a sandy grit was present on the bottom of the container the oil drained into when i emptied it from the car.
Where would this have come from?
Im guessing its the dodgy stainless mesh pod filter that came on my car letting crap into the engine.
I was horrified when i saw the grit in the oil.
Has this happened to anyone else?
Im thinking about getting a new pod filter now, i was looking on justjap.com at one of the apexi power intakes. Is this a good choice to go with?
thanks for any help.
cheers
are you sure it was sand? cause in that case it most probably would have gone in through the intake and perhaps scored the bores
could it be metal? have you just had your engine rebuilt?
nah havnt had the engine rebuilt.
Im pretty sure it was little bits of dirt and grit.
Was only very small but i know thats still enough to scores the bores.
Who knows, the previous owner in japan probably ran it without an air filter.
cheers
was it dispersed through the oil or at the bottom of the pan?
if its dispersed through the oil, then i have no idea what it is, maybe the oilk filter itself? or somethign worse?
if its on the bottom, i'd say its mroe likely that your pan was dirty before you drained the car
think about it.. oil is pretty viscous and grit isn't going to sink to the bottom and settle in a matter of minutes like it might with a less viscous solution such as water...
best of luck,
Warren
I cut open the old filter and there was nothing in it.
Im guessing that when i twisted off my old oil filter i must of brushed off some sandy shit from somewhere in my engine bay and it has fallen down into the pan.
cheers
i've had this happen regularly across 2 cars so it can't be particles in the oil. no reliability problems (touch wood :D) out of either car they have both been perfect motors.
i'm going along with the dirty oil pan + washing dirt down into the pan when you pull the old oil filter off and oil gushes down the side of the block.
    • Yeah i have R34 with factory small box and now RB25DET NEO swapoed and iam planning to upgrade to big box.  So i would be good as long as i do not change diff?
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
