Just looking for some adjustable camber arms for my R32 and JJR has these ones +/-4 deg. and wondering if anyone here has had them installed, and what you think of them.
Do they really have the 4 deg adjustment? any major dramas with them?
Please write about own experiences if possible, avoid the " I've heard that a mate of a mate....."
Cheers
Ric
https://www.sau.com.au/forums/topic/145921-jjr-upper-camber-arms/
  • Replies 55
yup i bought a set, installed them in the car, drove around the block and then jacked car up to double check tightness of everything and what do ya know... BOTH arms had cracked their welds.
demanded my money back and vowed never ever to buy another just jap product
which ones are we talking about? the dog-bone shaped ones?
If it is those ones I have a set in my car. as far as the adjustment goes I could only get a max of 2 degrees or thereabouts. this is because after they are screwed in a bit the two halves touch each other inside the turnbuckle. if you cut down those threaded sections you could get more adjustment.
they haven't failed me in any way, but after 1 trackday and about 150kms of driving they started squeaking like crazy. haven't been able to cure it yet.
Yes these are the ones, Front ones.
Are you serious Simon? thats not good at all, did you get any explanation from JJR as to why they could have cracked? installation or something?
How about some Noltec ones anyone tried this ones, how much adjustment can you get?
Cheers
Ric
ahh, mine are completely different to those ones which is why I asked. those are rears I believe. I was talking about some fronts.
i'm talking about these ones:
They have a very similar design to the ones i got from japan, except mine are symmetric. i.e. the threaded parts dont have 1 longer than the other. Seems to me like it would be more hassle to do this... 3 different parts instead of 2 different parts
Looking at the Noltec catalogue, adjustment is via the 2 parts of the arm sliding inside each other and then are locked with grub screws (think camber tops, that style of sliding and locking).
These designs are known for slipping when used for control arms. They also retail for $691.43 according to their site...
Have you thought about just getting camber adjustable bushes? These are under $200, last time I looked (a while ago) they were being redeveloped to stop the excessive wear of one of the bushes and they were also coming down in price. They have now come down to $187 (i think) so I assume they are now stiffer and last longer?
yes, i considered the noltel arms, but just couldn't see all those little cap screws holding the thing together.
the JJR ones I have a 'inspired' by the midori made upper arms. they are a good design. just need a little tweaking imo.
First off have a read of this thread;
http://www.skylinesaustralia.com/forums/in...mp;hl=spherical
Keep in mind that almost all of the “retail” camber kits are designed to REMOVE the negative camber that occurs when Skylines are lowered. This is because the “road car market” is far larger than the “race car market” and they are looking at excessive inside tyre wear as the major problem that they need to overcome by adjusting the camber.
Keeping that in mind, the standard R32 style upper control arm is 190 mm long, centre of the outer bolt to the centre of the inner bolt. Using the off the shelf adjustable, offset, outer bush (Whiteline etc) reduces that to 184 mm. This gives around 2 to 2.5 degrees of negative camber on an R32 with a ride height around 355 mm centre of wheel to guard with around 6.5 degrees of caster on a 2wd and 5.0 degrees on a 4wd.
That is usually enough camber/caster, provided sufficient anti roll is used (larger stabiliser bars), for most circuits. High speed circuits with long sweeping radius curves (eg; Philip Island) need slightly more camber.
So we use the off the shelf adjustable, offset bush (Whiteline etc) in the inner of the upper control arm. That reduces the length to around 180 mm. This gives around 3.0 to 3.5 degrees of negative camber on an R32 with a ride height around 355 mm centre of wheel to guard with around 6.5 degrees of caster on a 2wd and 5.0 degrees on a 4wd.
This 180 mm length seems to have been the minimum that ALL of the R32 camber adjusters have been made to. All of the brands of upper control arms that I have measured (Noltec, Nismo, Ikeya etc) all stop at 180 mm or longer. So choosing one brand over another to get more negative camber is pretty much a waste of time.
:) Cheers :)
Hi,
Just got these installed on my car, as Beer Baron says u can only get max -2degree adjustment out of them.
When i was deciding between the noltec one and the jjr one it was a fairly easy choice.
You should have a read of SydneyKid's thread on upper arms, very informative read.
http://www.skylinesaustralia.com/forums/in...showtopic=91064
Hope that helps.
Stan.
Woops, too slow in my reply.
Edited by SNG
Yeah they stay at -5 all the time. Pictures of my car sideways shows the outside tyre flat on the road so this is good.
Drift events in wa are months apart so ive been using standard arms for daily driving inbetween then come drift time I fit the JIC's (which takes me 45mins). It looks like garage-13.com are selling these arms from $175.
Willow.... Do garage-13 have a website? thats cheap as!
SK....was jsut having a look at the whiteline catalogue for these camber kits which is the part number im looking for? the only one they seem to have is only +/-0.5 deg. which seems extremely low adjustment, any help would be appreciated.
Cheers
Ric
What camber does it have with the standard arms fitted?
:wub: cheers :yes:
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
