hey all
i own a hr31 skyline and recently purchased a r32 gts4 4door skyline with a rb26.
i would like to do a bit of track work every now and again to really open her up!
the car has stock brakes at the moment and i really want to ugrade them but without spending anymore than $1500.
the car aslo has ABS
are r33 brakes much of an upgrade?
would the lines match up properly for the GTS-4?
could u guys tell me a good setup without goin over my budget of $1500?
thanks
luke
you could go with R33 GTS-t front rotors and calipers if you wanted... they are the same diameter (296mm) as R32 GTR (non-brembo) but are 2mm narrower in width (30mm as opposed to 32mm i believe).
not sure if you'll need to modify your lines or not... it's quite possible though.
to be honest, i can't really fault the standard R32 brakes (although with slotted DBA4000 rotors) on the track, with some good fluid and good pads, but i don't have as much power as you would, so it could be a different kettle of fish.
I have a RB25DET in my GTS4, pushing 180kW at all 4. What I've done with mine:
Slotted rotors all round.
Braided brake lines (probably the best mod) all round.
I used to have problems with pedal fade, but the braided lines seem to have almost eliminated that. Had a day at Simmons plains a while ago, and the brakes worked well all day.
And, if you keep the fluid fresh (ie change annually), it should pull up well all day, every day.
i don't see how changing to braided lines would help with fade resistance....
fade is to do with either boiling the brake fluid, or your pads not being of the right heat range and overheating basically.
braided lines addresses neither of these.
what it WILL give you, is a slightly solider pedal feel, as they will stop the line expanding/ballooning ever-so-slightly under hard braking. (though unless your standard rubber lines are very crap, you won't really notice the difference)
the Just Jap brakes are the best value for money by far. brand new 8 piston calipers on 356mm rotors with pads and braided lines for $2,200
http://www.skylinesaustralia.com/forums/in...howtopic=112347
I know you don't want to spend that much but nothing comes close to that price, I paid 1500 for used 4 spot brembos with used pads and used rotors a couple of years ago.
r33/34 gtr brembo brakes are the best bang for buck. dont waste your mony on slotted rotors n shit cos they do nothing for better braking.
you gotta get bigger discs.
but if thats out of your budget just use some really hi temp brake pads, such as sbs duel carbon or ds3000's. and good brake fluid
i'm REALLY dubious about these things, purely because they are an unknown entity...
they have not had rigorous testing, they are not proven, they are cheap, and (possibly) nasty...
i don't want to trust my car/my life to something that is unproven.....
duncan where was these 355mm rotors at?
I can't see it in that thread either, but they definately have them in stock I was going to get them instead.....but clearance to 17" rims I needed to run was a problem
i'm REALLY dubious about these things, purely because they are an unknown entity...they have not had rigorous testing, they are not proven, they are cheap, and (possibly) nasty...i don't want to trust my car/my life to something that is unproven.....
I agree with the concern, there is nothing more important than brakes. But its not right to say they are untested and unproven, they have been used on a heap of cars including track use.
I bought a set a few weeks back and will be running them on my race car on the track, and at Targa Tas next year.....I'll let you know if I have any problems. At least 3 other gtrs will be running them at Targa as well
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
