guard rolling tool?????
TTF (The Tyre Factory) Preston
On the Hume HWY. Between Bell Str. and Mohoney's Rd. on the left as you are heading outbound (Campbellfield).
I advise NOT to do it, as any rolling of gaurds can crack the paint. May not happen straight away, but may happen later on. No-one gives a garantee against cracking of paint around the gaurds.
I have 19" rims with 275/30/19(rear) - 245/35/19(front) rubber and still have not needed to roll my gaurds.
I have TEIN height and damper adjustable suspension. The car is lowered but not excessively, and the struts are fairly stiff (not much travell, on softest setting). The car would look alot meaner if lowered alot more, but i would then be required to roll the gaurds, and have to worry about speed humps, gutters, driveways, etc., which i could live without the hassle.
Keeping in mind that the rims are 19's. When i look at the gaurd from wheel hight, the wheel arche sits at the same point as the top of the tyre. This is possible a the rim is not flush or sticking out of the gaurds and the rubber curves in a little from the outside walls. I am unable to stick me finger between the gaurds and the rubber :) .
